Kyuubi™ Posted January 18, 2008 Report Posted January 18, 2008 Good Day! Can someone give me a sample code on how to make a trial period for my program?. My Idea is i want to read the processor number or board number of the cpu that the program has been installed. Then from that i want to generate a corresponding serial for it. Any idea for a trial period time will be greatly appreciated. thanks in advance and more power to LAVA :worship: . Quote
BrokenArrow Posted January 22, 2008 Report Posted January 22, 2008 QUOTE(Kyuubi™ @ Jan 17 2008, 08:30 PM) Quote Good Day!Can someone give me a sample code on how to make a trial period for my program?. My Idea is i want to read the processor number or board number of the cpu that the program has been installed. Then from that i want to generate a corresponding serial for it. Any idea for a trial period time will be greatly appreciated. thanks in advance and more power to LAVA :worship: . The way I've done this has been to write a date stamp to a binary file, which can be deeply embedded in other binary "junk" so that the file is quasi-encrypted. This file is the date of installation + n time. Then just have the program look at that file and compare it to the current date to see if the "trial" period (n time) has elapsed. Quote
MikaelH Posted January 22, 2008 Report Posted January 22, 2008 QUOTE(BrokenArrow @ Jan 21 2008, 12:42 PM) Quote The way I've done this has been to write a date stamp to a binary file, which can be deeply embedded in other binary "junk" so that the file is quasi-encrypted. This file is the date of installation + n time. Then just have the program look at that file and compare it to the current date to see if the "trial" period (n time) has elapsed. Hi I solved it like this: 1) I start by generating a Hardware specific key. -You can use the window GUI if you're running on a windows platform, this could be done via the registry VIs. -You can use the modify date of the LabVIEW.exe file, this will be the date you installed LabVIEW and 99.999% unique. 2) I created a small perl web-page that is connected to a mysql database. And then to activate the trail period, my LV application queries the web-page like this: www.mysite.com/CheckTrail.pl?HwKey=A75BE32F90115 The web page checks the database if this Hardware Key, already has activated it or not and return 0 or 1 that LabVIEW reads back. Cheers, Mikael Quote
Kyuubi™ Posted January 22, 2008 Author Report Posted January 22, 2008 QUOTE(BrokenArrow @ Jan 21 2008, 09:42 AM) Quote The way I've done this has been to write a date stamp to a binary file, which can be deeply embedded in other binary "junk" so that the file is quasi-encrypted. This file is the date of installation + n time. Then just have the program look at that file and compare it to the current date to see if the "trial" period (n time) has elapsed. Thanks for the reply . That's the initial solution that i did. works fine but i want to have a activation + unique hardware ID of the pc. QUOTE(MikaelH @ Jan 21 2008, 12:14 PM) Hi I solved it like this: 1) I start by generating a Hardware specific key. -You can use the window GUI if you're running on a windows platform, this could be done via the registry VIs. -You can use the modify date of the LabVIEW.exe file, this will be the date you installed LabVIEW and 99.999% unique. 2) I created a small perl web-page that is connected to a mysql database. And then to activate the trail period, my LV application queries the web-page like this: www.mysite.com/CheckTrail.pl?HwKey=A75BE32F90115 The web page checks the database if this Hardware Key, already has activated it or not and return 0 or 1 that LabVIEW reads back. Cheers, Mikael thanks for the solution . can you post a samble code on how to get a unique hardware specific key via registry VI? like for example the processor or board ID?. Thanks and more power!!! Quote
MikaelH Posted January 23, 2008 Report Posted January 23, 2008 QUOTE(Kyuubi™ @ Jan 21 2008, 06:54 PM) Quote can you post a samble code on how to get a unique hardware specific key via registry VI? like for example the processor or board ID?. Thanks and more power!!! Hi I meant the Windows GUID not GUI in my last post ;-) You can do this: http://lavag.org/old_files/monthly_01_2008/post-941-1200997564.png' target="_blank"> You can also parse the result of the system call "ipconfig /all" to get your MAC address. //Mikael Quote
Alexis Posted March 1, 2008 Report Posted March 1, 2008 QUOTE(MikaelH @ Jan 20 2008, 11:14 PM) Quote 2) I created a small perl web-page that is connected to a mysql database.And then to activate the trail period, my LV application queries the web-page like this: www.mysite.com/CheckTrail.pl?HwKey=A75BE32F90115 The web page checks the database if this Hardware Key, already has activated it or not and return 0 or 1 that LabVIEW reads back. Couldn't your user figure out via the firewall where it was querying, change their dns config to point to a simple webpage that just gives the 1 ? Just a thought. Quote
