Property Hierarchy in XControls?
Hi Folks,
Quick question. Is it possible in an XControl to have a custom property in the property node split into sub-properties?
What I mean by that is, can I create a property like X-Axis Setup that then branches into All, Title, Minimum, Maximum, etc. like e.g. the Bounds property splits into All, Left, Right, Top , Bottom?
Cheers,
Heiko
The wiki at least shows a way to have properties show up in sub menues.
That's quite nice, but it's still not all the way to what NI can do.
Until now, I didn't manage to create a cluster property that can be used as the complete cluster as well as it's elements.
If you don't know what I mean, have a look at the position or bounds properties of any control.
QUOTE(tcplomp @ Jan 19 2008, 04:22 PM)
OK, it seems I only went 90% of the way. I will try the rest as soon as I find the time.
Thanks for the pointer to your tool. I didn't try it until now, but looking at the documentation, it seems I should have done so some months ago. :thumbup:
