Thang Nguyen Posted February 6, 2008 Report Posted February 6, 2008 Hi everybody, I would like to ask you for recommendation to build the DSC VI server in LabVIEW 8.5. I would like to make a VI Server which controls 6 similar devices. In each device I have multiple controls, indicators. I think about building the clusters which will group these variables together so I have only to build one time. After deploying the server, I will have only some of shared variables instead of thousand of separate shared variables. This is a big server which will control and monitor thousand of variables. The idea is I don't know if it will be convenient to control a signal or read a sensor's parameter or not. This is the reason why I want to ask for your recommendations before I try it myself. Thank you so much for your time. Thang Nguyen Quote
LAVA 1.0 Content Posted February 6, 2008 Report Posted February 6, 2008 QUOTE(Thang Nguyen @ Feb 5 2008, 11:52 AM) Hi everybody,I would like to ask you for recommendation...This is a big server which will control and monitor thousand of variables. ... I have been watching the forums for anyone claiming to be able to handle thousands of I/O points using "Shared Varaibles" and can't recall seeing such a claim. So I still see the SV as a new un-tested technology so the best advise I can offer is... Benchmark all of critacal interactions early in your development. Better to find out ahead of time rather than later. Ben Quote
