crelf Posted February 21, 2008 Report Share Posted February 21, 2008 Hi All, I'm lookking for something (it's name escapes me for the moment) that holds cables - I used to have one at a previous employer: it's a rack that attaches to the wall and you can hang your RS-232 cables on it, as well as your 1m power leads, and your banana plug patch cables, etc. Anyone know what this is called? Better yet, anyone know of a type they use and like? Even better yet, anyone got a couple that they don't need anymore? cheers crelf -edit Found one! Quote Link to comment
AnalogKid2DigitalMan Posted February 21, 2008 Report Share Posted February 21, 2008 Darn Chris: I was expecting to see a pic from a bar on 4th St in Austin. Instead I see a query about Test cable Holders. Try DigiKey #'s 501-1113-ND, 501-1114-ND, and 501-1053-ND (all from Pomona) -AK2DM Edit: I see you already found one. You should get 2 for a nice pair. Quote Link to comment
Ton Plomp Posted February 21, 2008 Report Share Posted February 21, 2008 QUOTE(crelf @ Feb 20 2008, 07:48 PM) Hi All, I'm lookking for something (it's name escapes me for the moment) that holds cables - I used to have one at a previous employer: it's a rack that attaches to the wall and you can hang your RS-232 cables on it, as well as your 1m power leads, and your banana plug patch cables, etc. Anyone know what this is called? Better yet, anyone know of a type they use and like? Even better yet, anyone got a couple that they don't need anymore? cheers crelf -edit http://www.rapidonline.com/productinfo.aspx?&tier1=Cables+%26+Connectors&tier2=Connectors+-+Single+Pole&tier3=Test+Clips&tier4=Test+lead+wall+rack&moduleno=67869&catRef=17-2275' target="_blank">Found one! You had a spare room needing for your PXI/SCXI stuff and didn't had one of those? Ton Quote Link to comment
crelf Posted February 21, 2008 Author Report Share Posted February 21, 2008 QUOTE(AnalogKid2DigitalMan @ Feb 20 2008, 02:38 PM) I was expecting to see a pic from a bar on 4th St in Austin. Ohhh - I've got puh-lenty of those! QUOTE(AnalogKid2DigitalMan @ Feb 20 2008, 02:38 PM) Try DigiKey #'s 501-1113-ND, 501-1114-ND, and 501-1053-ND (all from Pomona) They look great - thanks! QUOTE(tcplomp @ Feb 20 2008, 02:46 PM) You had a spare room needing for your PXI/SCXI stuff and didn't had one of those? Yeah - I already have a rack to hold my spare PXI cards, but nothing for short cables: http://lavag.org/old_files/monthly_02_2008/post-181-1203537478.jpg' target="_blank"> (sorry about the quality - it's a camera phone) Quote Link to comment
T_Schott Posted February 23, 2008 Report Share Posted February 23, 2008 Hi, in a german it s called "Kabelrechen" => "cable rake" kabelrechen you can buy this from rsonline.de (german shop) http://de.rs-online.com/web/search/searchB...amp;x=0&y=0 Quote Link to comment
crelf Posted February 23, 2008 Author Report Share Posted February 23, 2008 QUOTE(T_Schott @ Feb 22 2008, 05:42 AM) you can buy this from rsonline.de (german shop) Wow - that *excatly* the one I bought for my old work! Thanks Quote Link to comment
Gabi1 Posted February 23, 2008 Report Share Posted February 23, 2008 QUOTE(T_Schott @ Feb 22 2008, 11:42 AM) you can buy this from rsonline.de (german shop)http://de.rs-online.com/web/search/searchB...amp;x=0&y=0 crelf: this one has the advantage of being adjustable, but stiff lamelles. with the simple rack, one always has problem fitting sma or smb connectors. however, much cheaper and easy to bend the lamelles (usefull to force entry... ). note: i would never had expected a forum topic about rack fittings... LAVA is great!! Quote Link to comment
orko Posted February 23, 2008 Report Share Posted February 23, 2008 I'm used to seeing cheap ones like This for $12-$13 USD As a side note, I never thought of the word origin of "rack" possibly being from the German "rake" (or vice versa). If that's the case, the shape of a typical cable rack does look like an upturned leaf rake... Quote Link to comment
T_Schott Posted February 27, 2008 Report Share Posted February 27, 2008 QUOTE(orko @ Feb 22 2008, 07:14 PM) As a side note, I never thought of the word origin of "rack" possibly being from the German "rake" (or vice versa). If that's the case, the shape of a typical cable rack does look like an upturned leaf rake... the german word for a leaf rake is "laub rechen" and i think a cable rack looks like an upturned leaf rake (ask for a rake at home depot ) Quote Link to comment
