Calling access DB on distributed sytem without MS Access installed
Hey.
My problem is that i'm using the ADO-toolkit to connect to a database. But apperently this relies on the host having MS access installed to work. Is there a way around this? Can i include an installer that will make the target able to call access db's?
I don't use the ADO toolkit, but it probably uses a connection string to determine which database to connect to, so you should be able to set a different string to use another DB. It probably does require the ADO libraries, but I think those are installed with Windows.
QUOTE(Klaus Petersen @ Mar 4 2008, 04:06 PM)
Hey.
If you install MDAC (already installed on recent Windows OSes like XP) you should be able to read Acess database files *.mdb) using a properly formatted DSN/UDN.
Rolf Kalbermatter
QUOTE (Klaus Petersen @ Mar 4 2008, 10:06 PM)
that's wrong. the ADO-Toolkit does not need Access to work properly
QUOTE (rolfk @ Mar 10 2008, 09:52 PM)
that's right. You have to install MDAC to use the ADO-Toolkit. MDAC is allready pre-installed on Windows 2k or higher, so you have to install it on Windows 98 or if you want to update your MDAC installation
