Programatic control of the Context Help Window
Does anyone knows if there is any way (involving scripting or not) to programatically get the context window to display a specific VI documentation?
For instance I am looking for something that would take a VI path and will get the help windows to display this VI documentation.
Thanks
PJM
I know you can use a property node to update a VI's description block, the content of which does appear in the Context Help window. You could simply read the help file into the program and pass it to description. That would be the only way I can think of to do it. Though could to think of it you can add help file links to a VI using the help tag and help path windows on the VI documentation window. These can also be updated via a property node programmatically.
I hope this helps.
Jason
QUOTE (PJM_labview @ Mar 26 2008, 03:24 AM)
This is a kludge (I know it's not what you want, but it's something that actually worked pretty well for an old project of mine): Open a reference to the VI that you want to get the data from, then read it's "VI Description" (it's a the text from the VI documentation), then feed that into the "Description" of the FP node that the mouse if over - the context help window will update with the new description of the FP node. (I *think* I had to do this on a "Mouse Move" event to make sure the context help window updated, but I don't remember...)
Hey - I warned you that it was a kludge :)
QUOTE (PJM_labview @ Mar 26 2008, 08:24 AM)
Thanks
PJM
Their is a private method to return the image of the VI icon including the wire descriptors (just as it is shown in the help window).
I'll look it up tomorrow.
Ton
QUOTE (crelf @ Mar 26 2008, 07:38 AM)
Chris,
I already contemplated this solution and I am keeping it as a backup solution because by doing this you can't have the VI icon image and terminal name like you have natively when mousing over an SubVI/Primitive.
Thanks though.
PJM
QUOTE (PJM_labview @ Mar 26 2008, 12:57 PM)
I already contemplated this solution and I am keeping it as a backup solution because by doing this you can't have the VI icon image and terminal name like you have natively when mousing over an SubVI/Primitive. Thanks though.
No worries - it's a pretty grotty way of doing things, but I can't think of any other way that would work. :(
QUOTE (tcplomp @ Mar 26 2008, 05:40 PM)
QUOTE (PJM_labview @ Mar 26 2008, 05:57 PM)
Et voila:
post-2399-1206556472.png?width=400
The Whisker info describes where the controls are located in the icon.
Ton
Thanks Ton, I am aware of this method, and there is another one that works for primitive (see image below). But I am trying to have the existing context help window to programmatically display a VI Description (like you have when you natively mouse over a SubVI/Primitive). I am not trying to rewrite the help window feature (although I may have to).
post-121-1206565658.png?width=400
Note1: The attached VI shown in the screenshot will crash LV for indices value around 330, so save your stuff if you want to play with this.
Note2: Here is one of the "primitive" image I got using this VI: Coerce to Type...
post-121-1206565899.png?width=400
PJM
QUOTE (PJM_labview @ Mar 26 2008, 05:13 PM)
Sorry mate, but I think you just answered your own question.
  • 1 month later...
QUOTE (PJM_labview @ Mar 26 2008, 10:13 PM)
Thanks
QUOTE
And did you?
Ton
The "Get Conpane Image" method also provides the help image for the VI.
post-1450-1209563163.jpg?width=400
BTW, the Coerce To Type function seems a conversion tool, probably unfinished. The description says: "Coerce the input to become the datatype associated with type and returns the results at the output terminal". Here you have a VI with the node.
Download File:post-1450-1209563170.vi
Saludos,
Aitor
Umm, is that a skull in the decompose and recompose icons...? :o
post-1450-1209566472.jpg?width=400
Ya, I played with the "Get Conpane Image" too.
I actually gave up trying to programatically control of the Context Help Window (or create my own one) for the time being.
About the decompose and recompose icons, I think you are right. This definitively look like a skull.
PJM
QUOTE (PJM_labview @ Apr 30 2008, 11:47 AM)
:question: I wonder if you could use a user32.dll (or the like - I don't remember right now) to make the context help window a child of a parent VI front panel window and manipulate the VI...
