How to convert an 8/16 or 32 bit image to a binary image?
Hi guys!!!
I was wondering how I can store an image which is represented in 8/16 or 32 bits into a binary image?
I know using IMAQ pallete, i can convert an image into an array using ImageToArray VI. However, the image will be represented in an 8 bit or 16 bit format. How can I achieve binary?
Please help.
Thanks
QUOTE (wan81 @ Apr 21 2008, 12:16 PM)
  Quote
Hi guys!!!
Please help.
Thanks
Though readymade binary file saving is not available you can convert the U8 image into binary format.
Please Find Attached Example
In the example above i have shown image as 1D array, I hope Converting 2D image data to 1D array isnt big deal
QUOTE (tushar @ Apr 22 2008, 01:41 AM)
  Quote
The approach is fine, but if you have the IMAQ package it is always better to use the IMAQ functions which are much faster and more memory efficient.
Getting an image as a large array and then manipulating the array usually highlights the weaknesses of LabVIEW.. dealing with large amounts of data usually invokes the memory manager, or an inadvertent copy or two, which more than likely will slow things down.
Like the previous poster suggested, threshold the image to produce a binary image using a number of available thresholding options for manual, automatic etc. from the IMAQ library.
Neville.
