Article - A Challenge to NI: Use your Application Builder
QUOTE (Jim Kring @ May 28 2008, 04:42 AM)
Hi
I hope NI will abandon the LLB structure they are using in the exe-file or at least add folder support in the a LLB, this will make it possible to store everything inside the exe-file.
One other painful thing I have is that a quite large application, with lot of classes and lvlibs, it takes me more then 30 minutes to build an executable and during that time I can't use my computer for something else, since LabVIEW uses all my resources.
Cheers,
Mikael
My first time was with a .lvlib :rolleyes:
So much for protecting my VI names with the library namespace!
It just dumped duplicate names outside of the .exe!! :throwpc:
Nice article Jim!
I hope I'm not thread jacking but I thought that 8.2 would put same namespace vi's inside the exe with mangled names? But in 8.5 this was changed to placing them outside the exe. I wonder why mangled names is not a build option.
QUOTE (David Wisti @ May 28 2008, 11:01 AM)
Nice article Jim!
The name mangling (renaming) was one of the main problems with building apps that used LV classes. So for 8.5, the algorithm that handled name collisions was made the same for all project library types.
