JasonXCX Posted May 30, 2008 Report Posted May 30, 2008 Some time ago somepeople was looking for a Low frequency generator. I am trying to learn LabView with good books and my computer , I draw this VI as an exercice. It run but I am sure that , it is not the best VI ever made. I am looking for your improuvements. Jason Quote
orko Posted May 30, 2008 Report Posted May 30, 2008 QUOTE (JasonXCX @ May 29 2008, 05:46 AM) Some time ago somepeople was looking for a Low frequency generator. I am trying to learn LabView with good books and my computer , I draw this VI as an exercice. It run but I am sure that , it is not the best VI ever made. I am looking for your improuvements. Jason I can't read French, but this looks like a good first attempt. There are some things that pop out at me: 1) The front panel is a little skewed. If you are going to have anything resizing with the panel, then you may want to have everything resize. I personally like to not have anything resize, and not show the scroll bars so that the FP is fixed...but that's a preference thing. 2) The BD is for the most part fairly clean. Good job! Even though I can't read the labels, I can understand the flow and logic behind the code. 3) You may wish to take the main code and place it into a subVI, with your parameters as inputs and waveform/results as outputs. This will clean it up a bit more. 4) Are you sure on your math to get X in radians for the input of the Sine function? I'm seeing (Phase/(360*Freq))*(Freq*2pi) for the first iteration of the loop. It's early yet in Seattle, so I may just need a second cup of coffee before I understand what you're doing here... 5) Alright, I need to know... what does this mean in English? http://lavag.org/old_files/monthly_05_2008/post-3266-1212090586.png' target="_blank"> My wife's name is very close to this: Carrie Sines... so I'm dying to know Quote
Yair Posted May 30, 2008 Report Posted May 30, 2008 QUOTE (orko @ May 29 2008, 10:55 PM) 5) Alright, I need to know... what does this mean in English? http://lavag.org/old_files/monthly_05_2008/post-3266-1212090586.png' target="_blank"> I don't speak French either, but I know that sinus is a sine and Google says that carré is square, so I assume it means "square sine wave". I'm not sure whether your wife will appreciate that or not... Quote
PaulG. Posted May 30, 2008 Report Posted May 30, 2008 QUOTE (Yen @ May 29 2008, 04:31 PM) ... I assume it means "square sine wave". There is no such thing as a "square sine wave". It's sinusoidal or it non-sinusoidal. It can't be both. Quote
Ton Plomp Posted May 31, 2008 Report Posted May 31, 2008 QUOTE (orko @ May 29 2008, 08:55 PM) My wife's name is very close to this: Carrie Sines... so I'm dying to know So Orko got a square wife QUOTE (PaulG. @ May 29 2008, 10:14 PM) There is no such thing as a "square sine wave". It's sinusoidal or it non-sinusoidal. It can't be both. I'm not sure but I remember from high-school that there is a sinus 'function' where the signal is flat during the first n degrees, maybe that's it? EDIT: It's a square wave Ton Quote
Yair Posted May 31, 2008 Report Posted May 31, 2008 QUOTE (PaulG. @ May 30 2008, 12:14 AM) There is no such thing as a "square sine wave". It's sinusoidal or it non-sinusoidal. It can't be both. I figured as much, but didn't feel like searching to make sure this isn't something that does exist and which I don't know about. For example, http://en.wikipedia.org/wiki/User:Kieff/Square_sine_and_cosine_functions' rel='nofollow' target="_blank">here's someone who thinks such a thing should exist. Anyway, from looking at the code it's clear, as Ton said, that it's a selection between a sine wave and a square wave. Quote
orko Posted June 1, 2008 Report Posted June 1, 2008 QUOTE (tcplomp @ May 29 2008, 09:22 PM) So Orko got a square wife Hey, they said it was http://www.youtube.com/watch?v=F_byVtHrGEM' rel='nofollow' target="_blank">Hip to Be Square! Quote
JasonXCX Posted June 1, 2008 Author Report Posted June 1, 2008 Thank you for your remarks . I can't read French, but this looks like a good first attempt. There are some things that pop out at me: 1) The front panel is a little skewed. If you are going to have anything resizing with the panel, then you may want to have everything resize. I personally like to not have anything resize, and not show the scroll bars so that the FP is fixed...but that's a preference thing. I will try this . The front panel is green because when I was at school we had some very old scopes ( oscilloscopes ) with the front panel green . The BD is for the most part fairly clean. Good job! Even though I can't read the labels, I can understand the flow and logic behind the code. You may wish to take the main code and place it into a subVI, with your parameters as inputs and waveform/results as outputs. This will clean it up a bit more. Yes it is the next step. Are you sure on your math to get X in radians for the input of the Sine function? I'm seeing (Phase/(360*Freq))*(Freq*2pi) for the first iteration of the loop. It's early yet in Seattle, so I may just need a second cup of coffee before I understand what you're doing here... It is the phase adjustments 5) Alright, I need to know... what does this mean in English? It the choice between sine ( sinus ) function and square ( carré ) function 010101 My wife's name is very close to this: Carrie Sines... so I'm dying to know Best regards to your wife . I will translate the Vi in english . Quote
zhpipo16 Posted June 5, 2008 Report Posted June 5, 2008 QUOTE (JasonXCX @ May 31 2008, 09:15 AM) Thank you for your remarks . I can't read French, but this looks like a good first attempt. There are some things that pop out at me: 1) The front panel is a little skewed. If you are going to have anything resizing with the panel, then you may want to have everything resize. I personally like to not have anything resize, and not show the scroll bars so that the FP is fixed...but that's a preference thing. I will try this . The front panel is green because when I was at school we had some very old scopes ( oscilloscopes ) with the front panel green . hello every body i speak french very well and that mean (sin signal or square signal) you cab chose with this key (t/f) it's clear? The BD is for the most part fairly clean. Good job! Even though I can't read the labels, I can understand the flow and logic behind the code. You may wish to take the main code and place it into a subVI, with your parameters as inputs and waveform/results as outputs. This will clean it up a bit more. Yes it is the next step. Are you sure on your math to get X in radians for the input of the Sine function? I'm seeing (Phase/(360*Freq))*(Freq*2pi) for the first iteration of the loop. It's early yet in Seattle, so I may just need a second cup of coffee before I understand what you're doing here... It is the phase adjustments 5) Alright, I need to know... what does this mean in English? http://lavag.org/old_files/monthly_05_2008/post-3266-1212090586.png' target="_blank"> It the choice between sine ( sinus ) function and square ( carré ) function 010101 My wife's name is very close to this: Carrie Sines... so I'm dying to know Best regards to your wife . I will translate the Vi in english . hello i speak french very well and that mean( chose sine or squar signale with this key (true/false) it is for generating a sine or square signal) Quote
