Altomare Posted June 20, 2008 Report Posted June 20, 2008 Hi, I would like to make my UI more professional using some .NET controls. In particular, I want to add a status bar like the one of internet explorer: messages, icons, hyperlink and some other functions. I am not an expert in .net controls and i am loosing in the very wide number of methods and properties. Is there anyone who developed something like this? Do you know where I can find some code on .net controls? Thanks a lot. Quote
crelf Posted June 20, 2008 Report Posted June 20, 2008 QUOTE (Altomare @ Jun 19 2008, 08:11 AM) I want to add a status bar like the one of internet explorer: messages, icons, hyperlink and some other functions. You can do that using .net controls, but you can also build your own pretty easily in LabVIEW. Have a look at xcontrols. Quote
yonatan.tidhar Posted June 20, 2008 Report Posted June 20, 2008 QUOTE (Altomare @ Jun 19 2008, 02:11 PM) I want to add a status bar like the one of internet explorer: messages, icons, hyperlink and some other functions. If you just need add status bar to your UI you should take look at this example: http://file:///C:/Program%20Files/National%20Instruments/LabVIEW%208.5/examples/general/controls/splitter.llb/Status%20Bar%20using%20Splitter%20Bars.vi' rel='nofollow' target="_blank">C:\Program Files\National Instruments\LabVIEW 8.5\examples\general\controls\splitter.llb\Status Bar using Splitter Bars.vi It`s good start for this kind of thing. Quote
Altomare Posted June 20, 2008 Author Report Posted June 20, 2008 Thanks, but they are not really windows style. DotNET controls are very nice and I'd like to use them. I did the status bar in some way (pls, see the picture attached), but I cannot autosize the bar, anchor it on the bottom and so on. I can find very few example with .NET controls. Regards Quote
Phillip Brooks Posted June 21, 2008 Report Posted June 21, 2008 You could add a splitter and configure it as described in this post (w/link to NI), then place your ActiveX control inside the bottom pane. Quote
Doon Posted June 21, 2008 Report Posted June 21, 2008 QUOTE (Altomare @ Jun 19 2008, 09:11 AM) Thanks, but they are not really windows style. DotNET controls are very nice and I'd like to use them. Altomare, I have always found the http://forums.msdn.microsoft.com/' rel='nofollow' target="_blank">MS Developer Network Forum to be quite helpful when hacking at the .NET framework. Also, a good book on the .NET framework is invaluable (and expensive). However, virtually all of the resources out there are in either VB or C#. I suggest that unless you need to incorporate .NET in LabVIEW (for example, to use the DataGridView control ), you are probably going to save a lot of time and heartache simply mimicking the window features as discussed above. One option is to take screen caps of windows and cut-and-paste components into front panel elements. This would give you a "professional" look without the headaches. I hope that helps, --H Quote
Tim_S Posted June 21, 2008 Report Posted June 21, 2008 QUOTE (Doon @ Jun 20 2008, 10:19 AM) I suggest that unless you need to incorporate .NET in LabVIEW (for example, to use the DataGridView control ), you are probably going to save a lot of time and heartache simply mimicking the window features as discussed above. You got me curious enough to take a short gander at the DataGridView. You wouldn't happen to have a simple example of using it? Tim Quote
Doon Posted July 2, 2008 Report Posted July 2, 2008 QUOTE (Tim_S @ Jun 20 2008, 11:24 AM) You got me curious enough to take a short gander at the DataGridView. You wouldn't happen to have a simple example of using it?Tim My primary impetus for using DataGridView was to create multi-typed tables. However, if I didn't need to use it, I would not have. My biggest problem with .NET in LabVIEW is the shear number of property and method nodes needed to get anything done (not unlike LV trees). Unfortunately, I have nothing I can release at this time, sorry. Check back in about a month. -H Quote
