Hansell Posted July 18, 2008 Report Share Posted July 18, 2008 Hi all, I just got LabView 8.5 to do some image acquisition and processing for a summer research job i'm doing. I would like to acquire some images via webcam, but when I go to the NI website to download the NI-IMAQ USB drivers, the link provided doesnt work (imaq_usb_installer_setup.exe file), so i cant even download it let alone install it. Is anyone else having this issue and can anyone provide me with a link to where I could download it? Thanks Quote Link to comment
Yair Posted July 19, 2008 Report Share Posted July 19, 2008 I'm not sure where you went, but the file linked to here downloads and runs just fine. Maybe you have firewall issues? Quote Link to comment
Klein Posted July 19, 2008 Report Share Posted July 19, 2008 QUOTE (Hansell @ Jul 17 2008, 03:32 PM) Hi all,I just got LabView 8.5 to do some image acquisition and processing for a summer research job i'm doing. I would like to acquire some images via webcam, but when I go to the NI website to download the NI-IMAQ USB drivers, the link provided doesnt work (imaq_usb_installer_setup.exe file), so i cant even download it let alone install it. Is anyone else having this issue and can anyone provide me with a link to where I could download it? Thanks Did you check these requirements below? "System Requirements: LabVIEW 7.0 or higher with NI Vision 7.1 or higher for the USB LabVIEW support - Vision Assistant 7.1 or higher for the USB Vision Assistant plugin module - Vision Assistant 8.0 or higher for the USB Express VI" The Imaq USB driver is freeware but it won't be installed with you don't have NI Vision... Unfornatelly.. Quote Link to comment
Neville D Posted July 19, 2008 Report Share Posted July 19, 2008 You might try the IVISION toolkit which is quite a bit cheaper than NI Vision. No point buying a $3k+ package to use with a $20 camera.. IVISION has a free trial period so you can check it out. Neville Quote Link to comment
GaryTan Posted August 2, 2008 Report Share Posted August 2, 2008 Can anyone explain to me what is IMAQ stand for? Quote Link to comment
Yair Posted August 2, 2008 Report Share Posted August 2, 2008 I never thought about it, but it probably stands for image acquisition, just like DAQ stands for data acquisition. Quote Link to comment
GaryTan Posted August 3, 2008 Report Share Posted August 3, 2008 QUOTE (Yair @ Aug 1 2008, 07:14 PM) I never thought about it, but it probably stands for image acquisition, just like DAQ stands for data acquisition. oh.... i see. than which means IMAQ= IMage AcQuisition. Is it? Quote Link to comment
crelf Posted August 3, 2008 Report Share Posted August 3, 2008 QUOTE (GaryTan @ Aug 1 2008, 10:34 PM) than which means IMAQ= IMage AcQuisition. Is it? Yes. Quote Link to comment
GaryTan Posted August 4, 2008 Report Share Posted August 4, 2008 I'm now start using the USB-IMQ. Its cool. a lot of stuff we can play with. I have a question on it. What will happen to usb-imaq if i use two identical web-cameras? Quote Link to comment
crelf Posted August 4, 2008 Report Share Posted August 4, 2008 QUOTE (GaryTan @ Aug 3 2008, 04:18 AM) What will happen to usb-imaq if i use two identical web-cameras? It's been a long time since I've used NI-IMAQ-USB, but, generally speaking, USB devices are enumerated when you plug them in for the first time. When you say "what will happen", what is it that you want to know? Quote Link to comment
Yair Posted August 4, 2008 Report Share Posted August 4, 2008 When I wanted to use USB cameras, I had the same question. A simple search of NI's site solved it in a couple of minutes. Quote Link to comment
GaryTan Posted August 4, 2008 Report Share Posted August 4, 2008 QUOTE (crelf @ Aug 3 2008, 09:24 PM) It's been a long time since I've used NI-IMAQ-USB, but, generally speaking, USB devices are enumerated when you plug them in for the first time. When you say "what will happen", what is it that you want to know? Ok.... Seems like you already provide me answer for my doubt. I just worried NI-IMAQ-USB will not able to differentiate two identical cameras. But since they will be enumerated when plug them in, than the situation mentioned should not be a problem. THX for your answer. QUOTE (Yair @ Aug 4 2008, 12:44 AM) When I wanted to use USB cameras, I had the same question. A simple search of NI's site solved it in a couple of minutes. YA...Thanks for the reminding. Almost forget about this. Quote Link to comment
Yair Posted August 4, 2008 Report Share Posted August 4, 2008 Here's a useful tip - go do that search now. Really. Quote Link to comment
atyab Posted August 27, 2008 Report Share Posted August 27, 2008 I'm using LabVIEW 8.6 with Vision Development Module 8.6. I have to use a USB and/or Firwire camera to take snaps triggered by an external singnal and then do some processing on the captured snaps. Then wait for the next tirgger singal and repeat the process. Things I've done:- 1. I've been able to receive the external singal via a SCB-68 in LabVIEW. 2. I've been able to do the required image processing in NI Visison Assistant 8.6 on an already captued image. What I need to do:- 1. I need to combine the two things in LabVIEW and make the processing sensative to the external singal. Troubles:- 1. I can't find the IMAQ USB and IMAQ IEEE 1394 VI's in my Function Pallet for LabVIEW 8.6. 2. How do I trigger a camera to take a snap and then ask it to do the same on the next trigger signal. Quote Link to comment
crelf Posted August 27, 2008 Report Share Posted August 27, 2008 QUOTE (atyab @ Aug 26 2008, 06:59 AM) I can't find the IMAQ USB and IMAQ IEEE 1394 VI's in my Function Pallet for LabVIEW 8.6. Have you installed NI-IMAQ for IEEE 1394 or NI-IMAQ for USB? You need to install them for them to show up on your palette. QUOTE (atyab @ Aug 26 2008, 06:59 AM) How do I trigger a camera to take a snap and then ask it to do the same on the next trigger signal. I suggest you look at using the trigger on the camera - you can set up LabVIEW to wait on an image from the camera (this is the most temporally accurate method). Quote Link to comment
GaryTan Posted August 28, 2008 Report Share Posted August 28, 2008 I'm using the usb IMAQ now. Anyone know how to set a size for a image? As all the images I took is the size of 320x240. I wish to make it bigger. I've try IMAQ SetImageSize. The result is the image become mess up. Quote Link to comment
atyab Posted August 28, 2008 Report Share Posted August 28, 2008 When I copied the following files and folder from LabVIEW 8.5 to LabVIEW 8.6, I got the IMAQ USB palette to show. C:\Programme\National Instruments\LabVIEW 8.5\examples\IMAQ\imaqUSB examples.llb C:\Programme\National Instruments\LabVIEW 8.5\menus\Categories\VisionMotion\vision7.mnu C:\Programme\National Instruments\LabVIEW 8.5\vi.lib\imaqUSB\imaqUSB.llb I asked NI and they say the IMAQ USB hasn't been updated for LabVIEW 8.6. I tried installing the IMAQ for IEEE1394 but still can't see the plaette for it. Is there a way to trigger the sanp using an external signal from inside LabVIEW instead of triggering it externally? Quote Link to comment
GaryTan Posted September 10, 2008 Report Share Posted September 10, 2008 Nobody can help me on that? Quote Link to comment
iowa Posted September 10, 2008 Report Share Posted September 10, 2008 QUOTE (atyab @ Aug 26 2008, 11:59 AM) I'm using LabVIEW 8.6 with Vision Development Module 8.6. I have to use a USB and/or Firwire camera to take snaps triggered by an external singnal and then do some processing on the captured snaps. Then wait for the next tirgger singal and repeat the process. Things I've done:- 1. I've been able to receive the external singal via a SCB-68 in LabVIEW. 2. I've been able to do the required image processing in NI Visison Assistant 8.6 on an already captued image. What I need to do:- 1. I need to combine the two things in LabVIEW and make the processing sensative to the external singal. Troubles:- 1. I can't find the IMAQ USB and IMAQ IEEE 1394 VI's in my Function Pallet for LabVIEW 8.6. 2. How do I trigger a camera to take a snap and then ask it to do the same on the next trigger signal. Please let me know if you were able to find these VIs Examples. I have similar chalanges of trying to incorporate WebCam into LabView. Have a need for: 1) Taking Pictures; 2) Processing pictures with OCR for texts extraction outputed as string. Thank you, Alex http://energyray.com Quote Link to comment
