vidur moudgil Posted August 21, 2008 Report Posted August 21, 2008 hi everybody, i have got a problem how can we make a front panel dynamic in such a way that suppose we select a case structure or press a button than the controllers and indicators corresponding to that choice r visible in the front panel not of other options?? Quote
Antoine Chalons Posted August 21, 2008 Report Posted August 21, 2008 QUOTE (vidur moudgil @ Aug 20 2008, 11:25 AM) hi everybody,i have got a problem how can we make a front panel dynamic in such a way that suppose we select a case structure or press a button than the controllers and indicators corresponding to that choice r visible in the front panel not of other options?? Hello, As far as I know you can not create controls/indicators dynamically. What you can do is place all the controls/indicators on the and use property nodes to hide/show only the controls/indicators corresponding to the selected case. Another way is having a tab control, and create one tab per case. I hope this helps. Quote
vidur moudgil Posted August 21, 2008 Author Report Posted August 21, 2008 QUOTE (Antoine Châlons @ Aug 20 2008, 01:12 PM) Hello,As far as I know you can not create controls/indicators dynamically. What you can do is place all the controls/indicators on the and use property nodes to hide/show only the controls/indicators corresponding to the selected case. Another way is having a tab control, and create one tab per case. I hope this helps. k thanx buddy now like i put a case structure and have many indicators in each case, watr should i do to make the indicator show only when case is running any idea??? i searched the property option for field corresponding to it couldnt find it Quote
Francois Normandin Posted August 21, 2008 Report Posted August 21, 2008 There's a "Visible" property of each control and indicator. Quote
Antoine Chalons Posted August 21, 2008 Report Posted August 21, 2008 QUOTE (vidur moudgil @ Aug 20 2008, 02:20 PM) k thanx buddynow like i put a case structure and have many indicators in each case, watr should i do to make the indicator show only when case is running any idea??? i searched the property option for field corresponding to it couldnt find it Here is a quick example in LabVIEW 8.5.1 with comment on the block diagram. Hope this helps Quote
Anders Björk Posted August 21, 2008 Report Posted August 21, 2008 QUOTE (vidur moudgil @ Aug 20 2008, 02:20 PM) k thanx buddynow like i put a case structure and have many indicators in each case, watr should i do to make the indicator show only when case is running any idea??? i searched the property option for field corresponding to it couldnt find it A tab control maybe useful, one tab or each case. Quote
vidur moudgil Posted August 22, 2008 Author Report Posted August 22, 2008 QUOTE (normandinf @ Aug 20 2008, 01:32 PM) There's a "Visible" property of each control and indicator. http://lavag.org/old_files/monthly_08_2008/post-10515-1219235557.png' target="_blank"> thanx buddy Quote
