jed Posted September 26, 2008 Report Share Posted September 26, 2008 I am now using VA 8.6 and it's crashing every five minutes. Basically my work flow is start-load-do_something-save-crash-KILL-Repeat. The save doesn't cause the crash; it eventually locks up no matter what I do, even if I leave it alone. I am on Vista on an NI PXI system. I had been using VA 7.1 for the last few years, and although that one didn't crash, I had serious problems with getting some of the fields to accept my selections and such, but never anything this bad. Anyone know anything about this? Quote Link to comment
Neville D Posted September 26, 2008 Report Share Posted September 26, 2008 You know, there is an upgrade to Vision 8.6.1 ? Also, since you were using 7.1 before, is your LV version compatible with Vision 8.6x? I am having a LOT of problems building an exe with Vision 8.6.1 and LV RT 8.6. I have narrowed it down to a IMAQ Find Circular Edge.VI which if excluded doesn't cause the build to fail. I will have to go back to LV 8.5.1 + vision 8.6.1 where everything worked fine. N. Quote Link to comment
Antoine Chalons Posted September 27, 2008 Report Share Posted September 27, 2008 QUOTE (Neville D @ Sep 25 2008, 09:46 PM) You know, there is an upgrade to Vision 8.6.1 ? Also, since you were using 7.1 before, is your LV version compatible with Vision 8.6x?I am having a LOT of problems building an exe with Vision 8.6.1 and LV RT 8.6. I have narrowed it down to a IMAQ Find Circular Edge.VI which if excluded doesn't cause the build to fail. I will have to go back to LV 8.5.1 + vision 8.6.1 where everything worked fine. N. Hello, I think this issue might be related to http://forums.lavag.org/upgarde-a-project-t11963.html&p=52276#entry52276' target="_blank">this thread. I'll post here when the fix is officially posted by NI on their knowledge base. And I PM you the info I have right now. Quote Link to comment
