Rolf Kalbermatter Posted November 18, 2008 Report Share Posted November 18, 2008 The OpenG PortIO package allows to access port adresses as well as physical memory adresses. This release (v1.2) adds support for physical memory acccess and also removes the actual kernel driver file from the system directory on uninstallation. You can download+install this package using VI Package Manager. Just press the "Check the Network for Available Packages" button to refresh your package list. Quote Link to comment
Neville D Posted November 18, 2008 Report Share Posted November 18, 2008 Doesn't seem to be any newer package than Version 1.1 of the Port I/O library.. Neville. Quote Link to comment
Francois Normandin Posted November 18, 2008 Report Share Posted November 18, 2008 QUOTE (Neville D @ Nov 17 2008, 06:46 PM) Doesn't seem to be any newer package than Version 1.1 of the Port I/O library..Neville. Same here. I had to download it straight from Sourceforge and install manually. (link on http://forums.jkisoft.com/index.php?showtopic=934' rel='nofollow' target="_blank">JKI) Quote Link to comment
Jim Kring Posted November 19, 2008 Report Share Posted November 19, 2008 Please try again -- it's now available for download from within VIPM. There can be a delay between when OpenG libraries are released and when the package becomes available in VIPM. Quote Link to comment
Neville D Posted November 19, 2008 Report Share Posted November 19, 2008 QUOTE (Jim Kring @ Nov 17 2008, 10:09 PM) Please try again -- it's now available for download from within VIPM.There can be a delay between when OpenG libraries are released and when the package becomes available in VIPM. OK, great! It worked fine this morning. Thanks, N. Quote Link to comment
