Renaming VIs Dynamically
Good Day ,
I am in need to Know Method to Rename Selected VIs In a large Folder. This Should Be Similar to Save as ,Substitute Copy For Original In
Run Time Menu.
Thanks in Advance,
Malani
QUOTE (Ton @ Dec 29 2008, 03:45 PM)
You can do it manually as Ton suggested or there is an Open G install by Jim Kring called Rename Folder of VIs that will install into your LabVIEW runtime menu.
QUOTE (Ton @ Dec 29 2008, 12:15 PM)
Ton,
I am Trying to Rename the VIs Dynamically Using Scripting Renaming by using Save Instrument is Similar to File-->Save AS-->Create Unopened Disk Copy. But I am Looking for some thing similar to File-->Save AS-->Substitute copy for Original .
As by using Save Instrument and deleting the Original Copy I was able to Acheive the Functionality but I Think That is In efficient.
So I am Looking for some other Algo or Functions In LabVIEW
Thanks Ton,
Malani
QUOTE (malani @ Dec 29 2008, 08:06 AM)
Ton,
What is inefficient about that? It's exactly how the Substitute copy for Original is implemented only without the delete afterwards as the original file remains on disk.
You do need to think about feelings you have. Just because something does feel inefficient does not mean it has to be so. If it works and does what you want, why going to try to make a supergalactic solution instead? Not even a NASA budget could help you there :rolleyes:
Rolf Kalbermatter
QUOTE (rolfk @ Dec 29 2008, 02:00 PM)
Rolf Kalbermatter
The advantage of substitute fir orginal copy is, I will get relinked in all the instances that are there in memory so, He just has to open the top level and Save all the VIs in memory or else he need to play with the VI Refnum and relink @ every instance
QUOTE (Variant @ Jan 2 2009, 09:52 PM)
Save Instrument, will link all items in memory to the new path, you only have to resave them (just as the menu option).
Ton
Thanks for All your Suggestions
Now Renaming all the VI in Folder Programatically Does work fine with all your Inputs.
The method save Instrument is not Inefficient But When I am Trying to Rename a Bulk of
Folder I tried if any Better option is Available.
Thanks,
Malani
