saving date, time and temperature value to lvm file
i am using labview 8.5. i am doing a temperature sensor project. i have use the write to measurement file and i successfully save the temperature value. however, the data format save not as i preferred. i just can save the temperature value but cant save the date and time. i plan to have the lvm file like this:
9/1/2009 20:00:00 28.54
9/1/2009 20:00:01 28.65
9/1/2009 20:00:02 29.00
9/1/2009 20:00:03 27.23
9/1/2009 20:00:04 28.99
how to do this? i have attached a print screen of my block diagram.
besides, i plan to add in another function which will recorded the temperature value based on the time selection i used. (for example 2 seconds a reading, 5 seconds a reading, or 10 seconds a reading). how to do this?
I don't find Lvm files very usefull and prefer in your case text file format like in my exempl.
post-5178-1231674485.jpg?width=400
Oups I have forget the carriage return that you need to concatenate at the end of string.
Eric
anders bjork: the data is use for recording purpose, which will be review back when needed.
bobillier: how to connect your block diagram to lvm file? the purple connection line cant be connected to the write to measurement file. what is the carriage return u mean?
I wish you better understand with this new draw. My proposition replace the Vi express "write to measurement File".
post-5178-1231753313.jpg?width=400
