File primitives operate on target of shortcuts
On Windows, the primitive File/Directory info returns info about the target file/directory when used on shortcuts, Open File on a shortcut opens the target and so on...
Do you think it is the appropriate behavior? For the OS itself, shortcuts are files.
If a VI lists a directory (as a shortcut C:\Folder1.lnk) and build a path with a listed file name, the result is wrong and unusable (e.g. C:\Folder1.lnk\file.txt").
One can check for the lnk extension but a file/directory can have this extension without being a shortcut... So how to be sure we deal with an actual file/dir instead of a shortcut?
QUOTE (neB @ Jan 15 2009, 12:37 PM)
The Recursive File List handles that situation by check the "shortcut" output.
Ben
Thanks. One more reason to upgrade to 8.6...
Still do you think the behavior is appropriate?
Ben
QUOTE (jpdrolet @ Jan 15 2009, 11:24 AM)
You speak of "OS" singular. There are many OSes, and not all of them treat shortcuts as files. LV's behavior is consistent across all the OSes that we run on.
