Jon Sjöstedt Posted January 22, 2009 Report Posted January 22, 2009 Hello all! How can I (programatically) detect if a terminal of a VI is wired (inside that VI with the possibly unwired terminal)? Comparing with a default value is not an acceptable soulution. I started thinking property node but got stuck there. Quote
Wire Warrior Posted January 22, 2009 Report Posted January 22, 2009 Changing the connection type to required on the connector pane isn't enough? Jason Quote
Francois Normandin Posted January 22, 2009 Report Posted January 22, 2009 QUOTE (Jon Sjöstedt @ Jan 21 2009, 08:22 AM) I started thinking property node but got stuck there. You will need scripting. I think I saw it once... never used it though. Quote
Yair Posted January 22, 2009 Report Posted January 22, 2009 This has been asked before. At least around the LV 8.5 timeframe, there was no property which returned if an input was wired or not and I doubt this was changed. There were some kludgy workarounds, but I found the invalid default value to be the simplest and easiest. Quote
Jon Sjöstedt Posted January 23, 2009 Author Report Posted January 23, 2009 Guess I have to seek other solutions. Default values or adding a boolean.Hmm... Thanks anyway! Quote
