LOGO! PLC driver based on LabVIEW
I'm happy because these past 2 weeks I have been working to decode and interpret the communication between the LOGO! PLC and a PC. Well ... I finished this work and achieved the following:
- Ask the status of communication between PC – LOGO! PLC
- Ask the status of the PLC (The PLC responds RUN/STOP status)
- Forcing the status of the PLC to RUN mode.
- Forcing the status of the PLC to STOP mode.
- Ask the current values (in real-time) of all channels of the PLC:
o 24 digital inputs
o 16 digital outputs
o 8 analog inputs
o 2 analog outputs
o 24 digital marks
o 6 analog marks
o 4 cursors
The application developed in LabVIEW performs the main function of communicate the Desktop / Laptop with PLC LOGO! (That is to say link National Instruments with Siemens ... ja ja). The software performs the following functions:
- Monitors and displays all channels of the LOGO!
- Choose the communication port.
- The user can save in a file all the data, each configurable period.
I have made many tests with different logic modules, and it has not given any problems.
In the image attached, I show you some of the topologies that can be implemented knowing this protocol of communication. I ask you to spread this to engineers/technicians who design and implement these MICRO-AUTOMATION systems, in order to offer this Software applicable to supervisory system or data-logger device.
I'm ready to be able to help.
post-8339-1237904029.png?width=400
Since you work for a university, you should probably not have a problem with uploading the code, right?
You could also submit it to NI's site.
Hi
me i have create something similar for millenium3 of crouzet to communicate via program cable like serial communication. if there is somebody interesting ...
Nice to have such a direct way.
We do the same, connect a PC to an Omron PLC with usb, but with a workaround.
OPC server works as the dataserver, both Labview and PLC are clients for datasharing, using global variables.
  • 5 years later...
to CarlosCalderon,
can you send me your file project LOGO!view.
please help me.
I hope this is for learning and to finish my final project.
I'm a basic user of LabVIEW and i need your help.
send me by email prasetyo.dte007@gmail.com
Thanks a lot
