Try Multiple Type Casts
Hmmm.
I don't really see he difference between your using the class name "problem" example and using an iterative apart from the class name has a descriptive case name and the iterative "trial and error" just has 0,1,2 etc. You still have to have a case to handle the particular type to do the correct cast but with the iterative approach you have to try all the previous ones first before deciding its not supported. With the class name its either supported or not.
Is there another benefit I'm missing?
It's stackable
It's scalable
Functionally I don't think it's any different, but there's a HUGE difference in readability. I suspect Norm has been spending a lot of time looking at customer's code lately. :)
(Personally I really dislike nested case structures. The logic is too hard to understand at a glance. If I can I'll usually execute all the logic tests, put the results in a boolean array, convert it to a number, and wire that into the case structure. Then I drop a comment explaining the logic. It's much easier for me to check the code that way.)
Oh, and without going back and watching the videos again, what was the first word Norm said on all four of the videos? ;)
Hmmm.
You did not see what happened with the XY graph did you?
You would have to account for EVERY possible child string.
EVERY CLASS NAME.
If you had some VI that had a GObject come into it's terminal,
you would need to manually enter the 'Class Name' for EVERY Class Name of EVERY child class that you wanted to handle.
If GObject was the input and you wanted to do a bunch of operations on all, or even a subset, of numerics types,
you would have to figure out every class name possible,
and then type it in perfectly in the case selector,
and then hope and pray that NI doesn't release another item in the GObject tree that now your code won't work with.
It's all about Scalability, robustness & re-usability. You do not get that w/ the string
Really? Its easier to read 0,1,2,3... than WaveFormGraph, WaveformChart, XYGraph... ?
I find nested case structures abhorrent. I must admit I didn't even consider the nested error example a solution :P Even a case structure with many cases causes me to look for an for an alternative. Its the same argument as Sequence Structures. If the case number is small (<6), I'd much rather use a select so its all out in the open. For more then I will try for strings unless its numerical in nature in which case I will do the same as you.
ummmm. "So"? :yes:
Thought I did :unsure:
EVERY CLASS NAME.
You mean the difference is that instead typing in the class name you wanted to handle you, would just "Copy Case" and change the cast constant instead?
Not really. Because unlike graphs the a property node accepts all the numeric classes for the common properties.
Certainly waveformchart,waveformgraph and xygraph don't have child classes. Neither do boolean, cluster etc
Numeric types are consistent (whether they be a U16, DBL, slider, knob,gauge or whatever) since all the common properties can be wired to the same property node. The graphs, however (I think) are the exception and it is only because the property node doesn't allow it (which it should) means that you have to handle them differently. I found that out when writing PassaMak.
Edited by ShaunR
Having slept on it (after all wise words from NI are never to be taken lightly). I thought I'd better to refresh my memory.
Unfortunately I seem to have remembered correctly (what? No crying emoticon?) as this works as I would expect
However, Plot color isn't available, yet it is still common to all plots.
Which brings me back to the summation that you have really highlighted a problem of inconsistency of the property node for waveform types since this also works.
So. You don't have to create a case for every class and subclass. Only the parent (if at all). Apart from some properties of waveforms (there maybe others but waveforms are the only one I've come across).
Edited by ShaunR
SO.....Dak, the problem is that it is functionally different. Check out the second video again. If someone made a piece of code that only had String Name case structures for ClassName WaveformChart & WaveformGraph, their code would fail to execute anything if those were the only two cases handled EVEN THOUGH the WaveformGraph case could have handled the XYGraph just fine.
Shaun, I agree that having the Class Available in the case selector would be better and maintain the robustness and flexibility of the pattern, but that requires a new type of stacked frame structure in LV to exist outside of a feature request
No, I'm saying w/ the design pattern, you don't have to make a special unique case for the XYGraph at all because the cast to WaveformGraph will not fail.
But as you've seen, not all common properties in class trees are common
Excuse me?? What?? Um, U B mistaken sir. XYGraph is a child of WaveformGraph
Thats assuming that you're trying to access properties and methods that exist in all cases for the common ancestor
You give me far too much credit sir.
Working in the tower has it's perks, but not the midas touch of LV wisdom.
Although easy access to the 3rd floor is damn nice.
SO.... this gets to the heart of your argument and the weakness in my example.
I stand by my example as a good simple case of showing why the string based operation fails and if someone was trying to make some generic code for waveform graphs they would easily miss the XYGraph case and need to go back and re-code
BUT!!! Where this code really shines is while doing LVScripting, where you end up with an array of GObject often and need to operate on a variety of types which a common ancestor with the needed functions can not be assumed or found.
EXAMPLE:
<object id="scPlayer" class="embeddedObject" width="944" height="566" type="application/x-shockwave-flash" data="http://content.screencast.com/users/NJKirchner/folders/Jing/media/4175933d-db01-4105-b527-c9935b5bc59f/jingh264player.swf">
<param name="movie" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/4175933d-db01-4105-b527-c9935b5bc59f/jingh264player.swf">
<param name="quality" value="high">
<param name="bgcolor" value="#FFFFFF">
<param name="flashVars" value="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/4175933d-db01-4105-b527-c9935b5bc59f/FirstFrame.jpg&containerwidth=944&containerheight=566&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/4175933d-db01-4105-b527-c9935b5bc59f/2010-09-11_1240.mp4&blurover=false">
<param name="allowFullScreen" value="true">
<param name="scale" value="showall">
<param name="allowScriptAccess" value="always">
<param name="base" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/4175933d-db01-4105-b527-c9935b5bc59f/">
<video width="944" height="566" controls="controls">
<source src="http://content.screencast.com/users/NJKirchner/folders/Jing/media/4175933d-db01-4105-b527-c9935b5bc59f/2010-09-11_1240.mp4" type="video/mp4;">
Your browser cannot play this video. Learn how to fix this.
</video>
</object>
By all means, keep using the 'Class Name' based selection of your code, but I believe you will find that, although it potentially meets your needs immediately, you have introduced a point of weakness into your code that unnecessarily would need modification to handle cases not originally though of. But why would you?
  • Like 2
Norm - this is really cool.
I think this part of the last video really hits home and defines the benefits of this design pattern, highlighting why using strings would cause an epic fail.
post-10325-001848800 1284246613_thumb.pn
I agree with Shaun in that strings are generally easier to read than integers in a Case Select, but in this case it doesn't really matter - the benefits are huge (you get some readability from the casted type anyways).
I can see the benefit of this straight away esp for scripting, and will be adding this to my templates folder.
Thanks for posting!
It was a trivial point but I think it improves readability immensely. And (probably in the minority again....but) I will choose readability over elegance if performance is not impacted..
But I want it to fail. Because it means I have given due consideration to an unexpected behaviour and therefore is a part of the designed behaviour. In the absence of similar behaviour in other classes, I almost view this as a NI implementation oversight (and therefore all methods more of a bug fix) rather than a design pattern to be used generically for accessing objects. In most cases (where things are as they should be) it's a performance hit since the probability is that you will be trying invalid cases before stumbling onto the correct one is high. If all t saves is 1 case. Then I see no reason to switch from an accepted, proven method to a shiny new method that may have performance hits and is (slightly) less readable. You'll have to give me more than that ;)
(What are the benchmarks comparisons like out of interest? If you don't have time, post an everyday example and I''ll do them)
All are as I'd expect EXCEPT graphs.
Excused! :lol:
Indeed I was. (It was late/early is my excuse and I'm sticking to it :D)
But my point (perhaps explained better after the sleep) was that I didn't need to create a case for EVERY class and subclass. And my memory from over 11 months ago, was that I didn't have t deal with subclasses. It turns out that was because of the consistency of implementation of the property node (In fact to handle any control in PassaMak only required 4 cases. So that's only 1 more than you have above.....for all of 'em)..
Well. Get banging on the floor, tool up your Pikachu with an Uzi and tell them to sort the Graph class out :D
Well I didn't miss it. And I didn't miss digital graphs either ;)
But. The string based system doesn't "fail". If you hadn't thought about the waveform graph or waveform chart, yours would "fail" too. I'm looking at the graph example and all I can see is that you are replacing a nested case structure with an iteratively nested case structure. Perhaps I need a different perspective?.:blink:
EXAMPLE:
Hmmm. Now I see no difference between the "string" based system and this one apart from the "string" one will always do it first time, every-time (if it can) but this method has to try a few different ones before either it hits one that works or it runs out of options. Same number of cases because there is no common denominator and each operation has different properties and methods.
It seems to me that the graph example is indeed a one-off scenario where you save 1 case.
How can you handle cases not originally thought of? :cool: If that were possible, you wouldn't have to add the extra cases because it can handle stuff you don't think about :D Moreover. If you haven't thought about them,how do you know it will handle them correctly?
(Wavey lines, Soft fade.....)
Many moons ago, in a galaxy far, far away. We used to use a similar approach for instrument identification. The SCPI spec was fluid and manufacturers all had their own way of identifying their device (to some extent that's still true today).. So we would have a list of all the ident commands for all the instruments we supported and try each one in turn until either we ran out or found one that worked Sales called it "Auto-detection". We called it the BFI method (Brute Force and Ignorance) :rolleyes:. It was slow and cumbersome and with hindsight, didn't obtain the holy grail of "future proofing" that many believed. It also had a really annoying habit that if a customer happened to stick on an unsupported device that had the same ident command. it'd make them think it was compatible but fall over because the rest of the command set wasn't the same. Eventually, we decided to make it a maintenance issue and that if they swapped out a device for a different one they'd just select it from a drop down list, It was faster, cleaner, easier to maintain and also meant that "if it 'aint on the list, it 'aint getting in".
Does this have anything to do with The "Any Cast Design Pattern"? Probably not. But but I'm having flashbacks :D
Ok then, replicate the code that I have that can handle changing both a control to an indicator and a constant to an indicator.
How many cases would you need for that w/ the string based implementation?
Well. For controls ........none. Since I wouldn't use any of them. I'd use something like this:
I can't remember off-hand how to get th BD reference (cannot seem to find it in the list). I'll have to dig into my old code
for a refresher example (is it only available if scripting is installed and activated?).
Yes, grab it from ni labs
And to clarify the challenge, make a sub-VI that takes an array of GObject references input and converts both constants and control terminals into indicators
Why don't you just send me your code and I'll mod it.:rolleyes:
  • 3 weeks later...
  • 1 year later...
http://www.screencast.com/users/Phallanx/folders/Jing/media/6d33f01c-4961-4c88-9944-e3290ab349a0
Remember.I'm not the one promoting a "Design Pattern". I'm only prepared to spend as much effort in discussion as you are! cool.gif
Not that I really want to get involved, but since you dug it up - in this video you don't just take the class name. You rely on every class inheriting from constant to have "constant" in its name, which could fail (for instance, knob and digital inherit from numeric). This could also be a problem with other classes which are called constant but don't inherit from constant, but that's presumably not an issue, because at most the cast will fail.
