drake27 Posted April 30, 2009 Report Posted April 30, 2009 Hello I have to get the name of the author of a VI but I don't know how to do this using Labview. If someone can help me Quote
Antoine Chalons Posted April 30, 2009 Report Posted April 30, 2009 QUOTE (drake27 @ Apr 29 2009, 03:28 PM) Quote HelloI have to get the name of the author of a VI but I don't know how to do this using Labview. If someone can help me In the sub-palette "Advanced Fils Functions" (Programming >> File I/O >> Advanced Fils Functions) you have a primitive called "Get Type and Creator". Hope this helps Quote
Grampa_of_Oliva_n_Eden Posted April 30, 2009 Report Posted April 30, 2009 QUOTE (drake27 @ Apr 29 2009, 09:28 AM) Quote HelloI have to get the name of the author of a VI but I don't know how to do this using Labview. If someone can help me I confess, I don't know what you are trying to do. Do you have a VI and you need to know who was the orignal author? If so post and maybe one of us can recognize it. Otherwise, please clairfy your question. Ben Quote
drake27 Posted May 1, 2009 Author Report Posted May 1, 2009 thanks Antoine It's just what I want to do Quote
Rolf Kalbermatter Posted May 5, 2009 Report Posted May 5, 2009 QUOTE (Antoine Châlons @ Apr 29 2009, 10:03 AM) Quote In the sub-palette "Advanced Fils Functions" (Programming >> File I/O >> Advanced Fils Functions) you have a primitive called "Get Type and Creator".Hope this helps But this returns always the same information for a VI????? What would that be good for? Rolf Kalbermatter Quote
drake27 Posted May 5, 2009 Author Report Posted May 5, 2009 Hi Yes I saw this problem. This function isn't a solution for my problem so if someone have another answer I hope this help Quote
Rolf Kalbermatter Posted May 5, 2009 Report Posted May 5, 2009 QUOTE (drake27 @ May 4 2009, 01:13 AM) Quote HiYes I saw this problem. This function isn't a solution for my problem so if someone have another answer I hope this help There isn't a common way to note the author of a VI. Some place a comment in the diagram, others on the front panel, others yet again on the VI description and last but not least there is the VI Property "History.Entire Text" that returns the names and comments of all the changes made to the VI, IF and only IF the user had this feature enabled, which most don't since it is a pain in the ######. In general a lot of VIs do not even contain information about the author at all. Rolf Kalbermatter Quote
