jgcode Posted August 8, 2009 Report Posted August 8, 2009 (edited) On 8/7/2009 at 5:43 PM, François Normandin said: so I put a VI Snippet. Just out of interest - the VI snippet does not include the Tagged Test VI.vi - which is the VI being statically referenced. Do people think it should or would be a good idea if it did? Edited August 8, 2009 by jgcode Quote
keiranwei Posted August 9, 2009 Report Posted August 9, 2009 (edited) It's perfect, I love it, thanks; But I like duplicate case becase some wire can be wired automaticly, So I update a version (only alte a piece of code) that has "Duplicate Case Here" shortcut menu,^_^ (In original code, the copy case function is here ,but why has no shorcut menu? Why I can't upoad my code? Edited August 9, 2009 by keiranwei Quote
Francois Normandin Posted August 9, 2009 Report Posted August 9, 2009 On 8/8/2009 at 3:05 AM, jgcode said: Just out of interest - the VI snippet does not include the Tagged Test VI.vi - which is the VI being statically referenced. Do people think it should or would be a good idea if it did? I don't think it should be added. (I made this snippet just because I didn't have the CCT installed on my portable computer.) Let's say you want to create a snippet of a JKI state machine (by the way, I tried and it works), would you expect all the VI's it contains to be included in the PNG? I think it could get real huge and a distribution package is probably a good idea! Quote
jcarmody Posted August 9, 2009 Author Report Posted August 9, 2009 On 8/9/2009 at 4:44 PM, keiranwei said: In original code, the copy case function is here ,but why has no shorcut menu? I haven't written it into the menu, but you can copy a case using drag & drop. I'll add it if there's enough interest, but I think it's faster using the mouse. Jim Quote
jcarmody Posted August 15, 2009 Author Report Posted August 15, 2009 On 7/27/2009 at 4:24 PM, PJM_labview said: When you duplicate a state, you could pre-populate the new name with the old state name (or ,may be even better, use the prefix such as if the state is "Macro: Initialize" the new state pre-populate name is "Macro:") The latest version does this. Thanks for the idea. On 7/28/2009 at 12:21 AM, Jim Kring said: new features I'd like to see: Rearrange Cases >> Alphabetically: I'd love to have a context menu item (in the tree) for "Rearrange Cases >> Alphabetically" (or similar). Note that this should ideally preserve the separators and groupings as are standard in the JKI State Machine. This is in the new version, too. Thanks, Jim Quote
jcarmody Posted August 15, 2009 Author Report Posted August 15, 2009 (edited) I just noticed that if I drag/drop to reorder a section header the entire section follows it! I'm better than I thought - coding features before having the idea. I'll spend some time figuring out why this works tomorrow... Edit - the Tree Control does this, not my program. It turns out that I'm only as good as I thought (or, perhaps, not even). Edited August 15, 2009 by jcarmody Quote
ssingh Posted August 15, 2009 Report Posted August 15, 2009 Please add download for LV 8.2 Version also Quote
jcarmody Posted August 15, 2009 Author Report Posted August 15, 2009 On 8/15/2009 at 7:31 AM, ssingh said: Please add download for LV 8.2 Version also I don't know what I did, but the 8.2 version isn't working. This is where the VI is broken: The VI is still reentrant if I just remove this element, but the Tree Control menu has gone away. I have some work to do, sorry. Any ideas? Quote
PJM_labview Posted November 6, 2009 Report Posted November 6, 2009 New Feature Request: * I think the "Insert case here" should duplicate a separator case (a case named "---------- UI ----------" for example) so all the necessary wire are already connected (error, application data, queue, ...). Alternatively, create a new command called "Duplicate case here" that does what I explain above. * The caseselect windows title should have the VI name in it so it is easy to know which one I am looking at when I have more than one case select editor opened. I actually think that nothing else beside the VI name is needed. PJM Quote
jcarmody Posted November 6, 2009 Author Report Posted November 6, 2009 On 11/6/2009 at 12:39 AM, PJM_labview said: New Feature Request: * I think the "Insert case here" should duplicate a separator case (a case named "---------- UI ----------" for example) so all the necessary wire are already connected (error, application data, queue, ...). Alternatively, create a new command called "Duplicate case here" that does what I explain above. That's a good idea, but I think everyone should use linked tunnels. That won't work for 8.2, though, so I'll do it. The 8.6 version allows you to ctrl-drag-and-drop/copy cases in the tree. Quote * The caseselect windows title should have the VI name in it so it is easy to know which one I am looking at when I have more than one case select editor opened. I actually think that nothing else beside the VI name is needed. I can't recall if I implemented it in 8.2, but 8.6 hides the CaseSelect window unless the source VI is active. I'll do it because it seems like a natural behavior. The support discussion is over here. Did you look at my last post? I had a question I need help with. Quote
asbo Posted November 6, 2009 Report Posted November 6, 2009 On 11/6/2009 at 1:17 AM, jcarmody said: That's a good idea, but I think everyone should use linked tunnels. That won't work for 8.2, though, so I'll do it. The 8.6 version allows you to ctrl-drag-and-drop/copy cases in the tree. I remember an issue with LabVIEW crashing if you CTRL+Drag'd linked tunnels. I haven't run into it yet, but it's certainly made me wary of them. 1 Quote
LV User Posted December 8, 2009 Report Posted December 8, 2009 New Feature Request: It will be nice if we can have a search state Control on the top. It could be a combo box where user will type a search string and the combo box will populate all the relevant States which contain that search string. It could be such a way that as when the user types the closest match case could be automatically shown to the user... this will be really useful when there are many states Rajkumar 1 Quote
jcarmody Posted December 8, 2009 Author Report Posted December 8, 2009 On 12/8/2009 at 5:58 AM, raj said: New Feature Request: It will be nice if we can have a search state Control on the top. [...] It should be easy enough to implement; I've added it to my list. How many states do you have that you even thought of this? Do you use the JKI State Machine or state headers? The tree will separate into sections if your states have headers like "---------- Section ----------". You can collapse/expand the states under these headers in the CaseSelect window. This makes it easier to find the state you need. Regards, Jim Quote
LV User Posted December 9, 2009 Report Posted December 9, 2009 On 12/8/2009 at 10:35 AM, jcarmody said: How many states do you have that you even thought of this? Do you use the JKI State Machine or state headers? The tree will separate into sections if your states have headers like "---------- Section ----------". You can collapse/expand the states under these headers in the CaseSelect window. This makes it easier to find the state you need. Regards, Jim Typically while debugging, we will be looking to someones code. We will not be really familiar with their naming convention of the State and also the way they organize the states. It will be time consuming and painful to find the states in their state machine. I always felt if there were search in the case selection it would be really useful for quickly navigating the cases. I had to debug very large state machine which had more than >30 cases. Quote
jcarmody Posted December 9, 2009 Author Report Posted December 9, 2009 On 12/9/2009 at 6:08 AM, raj said: Typically while debugging, we will be looking to someones code. We will not be really familiar with their naming convention of the State and also the way they organize the states. It will be time consuming and painful to find the states in their state machine. I always felt if there were search in the case selection it would be really useful for quickly navigating the cases. I had to debug very large state machine which had more than >30 cases. Now I understand. Stay tuned... Quote
jcarmody Posted December 21, 2009 Author Report Posted December 21, 2009 On 12/9/2009 at 6:08 AM, raj said: Typically while debugging, we will be looking to someones code. We will not be really familiar with their naming convention of the State and also the way they organize the states. It will be time consuming and painful to find the states in their state machine. I always felt if there were search in the case selection it would be really useful for quickly navigating the cases. I had to debug very large state machine which had more than >30 cases. Would it work for your purposes to have it search for states that begin with, rather than contain, the string being typed? I've added this functionality, but haven't made it search inside state names. Lemmeno. Jim Quote
