support for mouse wheel
I fear I'm missing something obvious. I want to scroll an array indicator with the mouse wheel and this is what I came up with:
Is there an easier way?
Thanks,
Jim
What event are you using to trigger this code?
None, it's in the timeout case (which is also polling to see if a case structure is selected).
Polling...bummer. I really wish they would give us a mouse scroll event!
I'm doing this as part of the work associated with this post. I wonder if I can detect that a Case Structure has been selected by some method other than polling. I'd still have to poll to handle scrolling through the long lists.
This sounds like a topic for another post on the VI Scripting forum... I'll try to figure it out myself first.
Would the Mouse Up event be a good time to check if a Case Structure has been selected instead of constant polling? I can think of no ways to select a case structure other than with a left-click or a "mouse down-drag-mouse up" combination. (unless selected programmatically of course).
I think if you enable the scrollbar on the array control it should work with the wheel. If not, then the one on a listbox should.
P.S.
So would I.
Doh! Duh... Thanks.
Doh! Duh... Thanks.
I think I slapped my head too soon. I'm trying to detect that a Case Structure was selected in another VI so I need to detect an event at the Application level, no?
You're totally right. Would there be a way to create a dynamic event to monitor for Mouse Up everytime a new VI is activated (App.VI Activation)? Unfortunately, I don't have time to hazard myself this way...
