Angelo1 Posted July 28, 2009 Report Share Posted July 28, 2009 Hello Lava's, I am still quiet new to LabVIEW. I am working on my final project for graduation. My task is to develop a machine control automation, which allows the user to set up the machine with the wanted parameters and then let the machine automatically run through the whole process. The machine itself is fairly simple and the functions are all programmed. I am slowly getting deeper into LabVIEW. I finished the programming of all functions and am trying to make the user interface more intuitive. When I search for a control, indicator or property node, it will be highlighted on the FP or BD with a black frame which then disappears. I would like to have such an effect for some buttons on my FP. For example when the user makes any changes to the settings, they need to confirm the new settings or discard them. Having an event looking for value changed and then highlighting the confirm, discard buttons in the way LabVIEW does it during editing would be nice. I did not find any property node for that. Is it possible? Thank you very much, Newby, Angelo ;-) Quote Link to comment
jg69 Posted July 28, 2009 Report Share Posted July 28, 2009 Yes, it is possible. Set the property node "KeyFocus" to "True" and the Control gets a black frame indicating that it has the key focus. Jens Quote Link to comment
Angelo1 Posted July 28, 2009 Author Report Share Posted July 28, 2009 Yes, it is possible. Set the property node "KeyFocus" to "True" and the Control gets a black frame indicating that it has the key focus. Jens Thank you Jens, The black frame I get with key focus is the right direction. However it is not exactly what I was looking for. -Angelo Quote Link to comment
Black Pearl Posted July 28, 2009 Report Share Posted July 28, 2009 The property is ObjHighlight (or similar). I'm not sure if it is public in your version. It has been around as private at least since 7.1 and made public recently (8.6 ?). So for 8.5 you will need to activate the scripting license (it is available for free on ni.com) and hope it is included with it. Or you get an old LV version where the ini keys worked and import it in your current version. Felix Quote Link to comment
jcarmody Posted July 28, 2009 Report Share Posted July 28, 2009 I did not find any property node for that. Is it possible? Yes, but with an invoke node. This'll make the control flash momentarily. Quote Link to comment
Angelo1 Posted July 28, 2009 Author Report Share Posted July 28, 2009 Thanks All, It seems this works only in LabVIEW 8.6. I guess I will stick to my changing colors... -Angelo Quote Link to comment
JustinThomas Posted July 28, 2009 Report Share Posted July 28, 2009 (edited) You could use the 'Blinking' property too. Edited July 28, 2009 by JustinThomas Quote Link to comment
Angelo1 Posted July 28, 2009 Author Report Share Posted July 28, 2009 You could use the 'Blinking' property too. Yes, that was the first thing I tried. I was not very satisfied... ;-) -Angelo Quote Link to comment
PaulG. Posted July 28, 2009 Report Share Posted July 28, 2009 You could use the 'Blinking' property too. I would be careful using the blinking property. I've worked in environments where using a blinking LED was as bad as your team finding out you wear dinosaur pajamas. Quote Link to comment
Rolf Kalbermatter Posted July 28, 2009 Report Share Posted July 28, 2009 The property is ObjHighlight (or similar). I'm not sure if it is public in your version. It has been around as private at least since 7.1 and made public recently (8.6 ?). So for 8.5 you will need to activate the scripting license (it is available for free on ni.com) and hope it is included with it. Or you get an old LV version where the ini keys worked and import it in your current version. Felix No scripting license from NI for LabVIEW < 8.6 and I don't expect that to come really. You can get it to work on non Windows versions by copying some files and editing the INI file but on Windows there is no way to get it to work without helping hands from NI to get the right license file and as I already said I'm not seeing that happen anytime soon, and with the next version of LabVIEW being just around the corner the chances for that get even smaller. Rolf Kalbermatter Quote Link to comment
Francois Normandin Posted July 28, 2009 Report Share Posted July 28, 2009 Yes, but with an invoke node. This'll make the control flash momentarily. Doesn't that work only in Edit Mode? Quote Link to comment
Angelo1 Posted July 28, 2009 Author Report Share Posted July 28, 2009 Doesn't that work only in Edit Mode? As I understand, it works also in running VI's in LabVIEW 8.6. I tried and figured out that I can use it in Edit Mode (only) even in LabVIEW 8.5. -Angelo Quote Link to comment
Francois Normandin Posted July 28, 2009 Report Share Posted July 28, 2009 As I understand, it works also in running VI's in LabVIEW 8.6. I tried and figured out that I can use it in Edit Mode (only) even in LabVIEW 8.5. -Angelo OK, then it's only documentation that wasn't updated in 8.6. Quote Link to comment
jcarmody Posted July 28, 2009 Report Share Posted July 28, 2009 Doesn't that work only in Edit Mode? I'm using it in an ATE to draw attention to a Boolean array when running the hardware in debug mode. I got so frustrated after REPEATEDLY not noticing that the UUT had stopped responding to me as I was happily wiggling input lines... The VI is running from the development environment, but it is running. Quote Link to comment
