MikaelH Posted September 18, 2009 Report Posted September 18, 2009 Hi My version of LabVIEW is behaving odd when it comes to Data Entry limits. Have YOU seen the same problem? When I open the “Data Entry…” option for a numeric the first time it does show me the right limits for that control. When I open the same option for the next numeric control these values don’t show the correct values. They still show the first opened control’s Data Entry-limits. And if I change the values, that values changes for the other control not the one I open the dialog from. This is in LabVIEW 8.6 Cheers, Mikael Quote
Kurt Friday Posted September 18, 2009 Report Posted September 18, 2009 Hi My version of LabVIEW is behaving odd when it comes to Data Entry limits. Have YOU seen the same problem? When I open the “Data Entry…” option for a numeric the first time it does show me the right limits for that control. When I open the same option for the next numeric control these values don’t show the correct values. They still show the first opened control’s Data Entry-limits. And if I change the values, that values changes for the other control not the one I open the dialog from. This is in LabVIEW 8.6 Cheers, Mikael Weird, I see the same thing. It looks like the Numeric Properties Data Entry tab page isn't refreshing with properties of the current control but rather keeps the settings of the last control edited. I'll check LV9 and see if it's the same dea. Edit LV9 is OK Quote
jgcode Posted September 18, 2009 Report Posted September 18, 2009 (edited) Hi My version of LabVIEW is behaving odd when it comes to Data Entry limits. Have YOU seen the same problem? When I open the “Data Entry…” option for a numeric the first time it does show me the right limits for that control. When I open the same option for the next numeric control these values don’t show the correct values. They still show the first opened control’s Data Entry-limits. And if I change the values, that values changes for the other control not the one I open the dialog from. This is in LabVIEW 8.6 Cheers, Mikael This patch (for 8.6.1) may help??? The Data Entry Properties Dialog Box for Numeric Controls Do Not Work Correctly in LabVIEW 8.6.1 http://digital.ni.com/public.nsf/allkb/765EBEBE6568CB098625756700718B66 Cheers JG [edit] Yep, I was right, it seems fix is to install 8.6.1 and patch. Hope you have a copy of 8.6.1?? http://zone.ni.com/devzone/cda/tut/p/id/7324 147779 Return "Data Entry" tab of Numeric Controls does not update properly "Data Entry" tab of properties dialog only applies to the first numeric control for which the dialog is opened per launch of LabVIEW. This issue exists in LabVIEW 8.6.1. Workaround: The LabVIEW 8.6.1f1 Patch has been released for this issue. KB 4UNGLN0R also has detailed workarounds. Reported Version: 8.6.1 Resolved Version: 8.6.1 Added: 02/26/2009 [/edit] Edited September 18, 2009 by jgcode 1 Quote
MikaelH Posted September 18, 2009 Author Report Posted September 18, 2009 Thank you. This fixed it. I'm happy again //Mikael Quote
jgcode Posted September 18, 2009 Report Posted September 18, 2009 Thank you. This fixed it. I'm happy again //Mikael Good to hear Quote
Rolf Kalbermatter Posted September 21, 2009 Report Posted September 21, 2009 This bug should only appear in 8.6.1. I didn't notice it in 8.6. But the 8.6.1f1 Fix is the right solution for it. Rolf Kalbermatter Quote
