Christina Rogers Posted October 23, 2009 Report Posted October 23, 2009 I've moved my blog to my own server (because some employers block blogspot.com). Is there any way to update existing LAVA links to point to the new location? eyesonvis.blogspot.com -> eyesonvis.com/blog e.g. Old URL: http://eyesonvis.blogspot.com/2009/08/improved-block-diagram-cleanup-in.html New URL: http://eyesonvis.com/blog/2009/08/improved-block-diagram-cleanup-in.html Quote
PaulG. Posted October 24, 2009 Report Posted October 24, 2009 Hello, Guru. No worries, at least for me. I have learned a lot from you and I have your new URL bookmarked. Good luck with your new server. Quote
crelf Posted October 24, 2009 Report Posted October 24, 2009 I've moved my blog to my own server (because some employers block blogspot.com). Is there any way to update existing LAVA links to point to the new location? Do you mean all the links you've ever posted? Hmmmm - I don't think there's an easy way to do that other than editing each individual post. Anyone with php knowledge got any ideas? Quote
ShaunR Posted October 24, 2009 Report Posted October 24, 2009 (edited) Do you mean all the links you've ever posted? Hmmmm - I don't think there's an easy way to do that other than editing each individual post. Anyone with php knowledge got any ideas? Search and replace SQL on the database with PHPMyAdmin. heres an example. Its not that difficult. http://www.zimmertech.com/tutorials/php/60/mysql-search-replace-phpmyadmin.php Edited October 24, 2009 by ShaunR Quote
Ton Plomp Posted October 24, 2009 Report Posted October 24, 2009 Do you mean all the links you've ever posted? Hmmmm - I don't think there's an easy way to do that other than editing each individual post. Anyone with php knowledge got any ideas? I assume you mean sql or mysql instead of PHP? Ton Quote
crelf Posted October 24, 2009 Report Posted October 24, 2009 I assume you mean sql or mysql instead of PHP? Yes Ton, I did mean SQL instead of PHP. Thank you so much for correcting me. Quote
