nil Posted July 20, 2004 Report Posted July 20, 2004 :worship: There are many .mnu files in the folder of \LabVIEW 7.0\user.lib,but when i open them in UltraEdit i have no idea what they consist of.So i just want to know what are they and how to make a .mnu file myself ,by labview or other editor?Thanks for help. Quote
Jim Kring Posted July 20, 2004 Report Posted July 20, 2004 nil said: :worship: There are many .mnu files in the folder of \LabVIEW 7.0\user.lib,but when i open them in UltraEdit i have no idea what they consist of.So i just want to know what are they and how to make a .mnu file myself ,by labview or other editor?Thanks for help. 1182[/snapback] There are binary files, and only NI has the tools to read and write them. These can be created using the palette editor. There are instructions in the LabVIEW User Manual. Quote
Michael Aivaliotis Posted July 20, 2004 Report Posted July 20, 2004 You should not edit the mnu files directly. Go to your LabVIEW menu and select tools>>Advanced>>Edit Palette Views. This will bring up the palette editor. From this editor you can edit exisitng subpalettes by right-clicking on the nodes or you can create your own mnu file. You can only create custom mnu files in your user.lib subpalette. Once you insert a submenu you will be given a choice to create a new mnu file. I hope this gives you some starting point with mnu files. There is extensive help in the built-in LabVIEW help on this topic. Quote
nil Posted July 21, 2004 Author Report Posted July 21, 2004 When i install some thirdpart code-packs, it seems there is a .mnu file in every sub folder such as openG's toolset and Adlink's driver pack,and the .mnu files change automatically when their installed path changed. How to make this?And in openG toolsets there are some subvis that when it is put onto the diagram,there shows no vi's icon but vi's diagram block,i found this only related to its mnu file.I think this can be very useful.How can this be achieved? Download File:post-449-1090386869.bmp 1 Quote
Michael Aivaliotis Posted July 23, 2004 Report Posted July 23, 2004 nil said: When i install some thirdpart code-packs, it seems there is a .mnu file in every sub folder such as openG's toolset and Adlink's driver pack,and the .mnu files change automatically when their installed path changed.1187[/snapback] What I described to you in my post is exactly how this is done by the suppliers of toolkits for LabVIEW. There really is not much more to it. When the VI's are distributed, mnu files are included. I'm not sure what you mean by "the .mnu files change". The .mnu files included with the toolkits always reflect the VI's they are included with. nil said: And in openG toolsets there are some subvis that when it is put onto the diagram,there shows no vi's icon but vi's diagram block,i found this only related to its mnu file.I think this can be very useful.How can this be achieved?1187[/snapback] Ah well this is called a "Merge VI". Here are some links for more information: http://forums.lavausergroup.org/index.php?...findpost&p=1121 http://digital.ni.com/public.nsf/websearch...52?OpenDocument Quote
nil Posted July 23, 2004 Author Report Posted July 23, 2004 hi Michael Aivaliotis,thanks a lot,it really helps me a lot! Quote
Q^Q Posted September 1, 2007 Report Posted September 1, 2007 QUOTE(nil @ Jul 20 2004, 10:21 PM) Quote :worship: There are many .mnu files in the folder of \LabVIEW 7.0\user.lib,but when i open them in UltraEdit i have no idea what they consist of.So i just want to know what are they and how to make a .mnu file myself ,by labview or other editor?Thanks for help. Use the http://community.ni.com/examples/palette-api/' target="_blank">Palette API Quote
Yair Posted September 1, 2007 Report Posted September 1, 2007 QUOTE(Q^Q @ Aug 31 2007, 10:37 AM) Quote Use the http://community.ni.com/examples/palette-api/' target="_blank">Palette API I understand you created it, so you would probably be the best person to ask - will it work in LV 7.x (which is what the original posted seems to have)? I don't have 8.0, so I can't try to open it and backsave. Quote
JDave Posted September 1, 2007 Report Posted September 1, 2007 QUOTE(yen @ Aug 31 2007, 05:59 AM) Quote I understand you created it, so you would probably be the best person to ask - will it work in LV 7.x (which is what the original posted seems to have)?I don't have 8.0, so I can't try to open it and backsave. Maybe in the last three years they have upgraded. It is nice to see functionality like this be available. :thumbup: Quote
Neville D Posted September 1, 2007 Report Posted September 1, 2007 QUOTE(nil @ Jul 20 2004, 07:21 AM) Quote So i just want to know what are they and how to make a .mnu file myself ,by labview or other editor? You can't create mnu files by yourself. These are the files that define your pallet views. The ones you generate when changing the default pallet set are stored in *\LabVIEW Data\8x\Pallets. If you want to change your pallet views, goto Tools>Advanced>change pallet set (I don't remember if this was the location for changing pallets in 7.x, but just search LV help for "editing pallets") Neville. Quote
Yair Posted September 2, 2007 Report Posted September 2, 2007 QUOTE(dsaunders @ Aug 31 2007, 05:56 PM) Quote Maybe in the last three years they have upgraded. Well, I still use LV 7.0 (which is great), so my reasons in this are slightly more egotistical, because I could potentially use this functionality for something specific. Quote
Achtu Posted December 31, 2024 Report Posted December 31, 2024 Quote When i install some thirdpart code-packs, it seems there is a .mnu file in every sub folder such as openG's toolset and Adlink's driver pack,and the .mnu files change automatically when their installed path changed. How to make this?And in openG toolsets there are some subvis that when it is put onto the diagram,there shows no vi's icon but vi's diagram block,i found this only related to its mnu file.I think this can be very useful.How can this be achieved? Expand Can you please provide an up-to-date solution to the question? 1 Quote
