Stop Run time engine
Bobillier
Yes, but it is not the most elegant way to do it as it may produce a flickering window on the screen - and it will force everything to stop at the instant it is run.
A tidier way to do it is to make sure all internal processes are terminated properly and then close every window the application has opened. When the last window is closed the application (and its use of the RTE) will stop.
Mads
Hi
I want to know if this vi ,post-5178-005486000 1284395186_thumb.pngstop the labview run time engine.
Eric
Yes, i'm agree . But in my program, i want to run few vi dynamicaly. In normal case, all those vi's are stop cleanly. But in case of the main program crash, i want use this function to be sure that all those vi are stop.
Eric
