mje Posted September 21, 2010 Report Posted September 21, 2010 I'm having a slight issue where I'm getting warnings appearing in some of my VIs that use event structues: The above code appears to be fine, but once I run it, the VI generates a warning in the error list. Quote Block Diagram Warnings Event Data Node: cluster has unnamed or duplicate named elements Details: The cluster being bundled or unbundled by name has elements with no name, or elements with the same name. So yeah...am I going crazy here? There's no custom objects or types involved, no other cases in the event structure, what you see in the snippet above is what you get. Is the warning being misassigned, or is there really a problem with the event data that is signalled for in this case, a boolean button? I find the warning annoying since I'm trying to clear a re-use library of all warnings, and I need to wade through several of these... Example VI is attached (2010)... duplicate names.viFetching info... Quote
crossrulz Posted September 21, 2010 Report Posted September 21, 2010 where is this error list you speak of? Quote
mje Posted September 21, 2010 Author Report Posted September 21, 2010 If I look at the error list (same one that appears if you try to click on a broken run arrow, or use the Ctrl+L key), and have the "Show Warnings" box checked, you should see it. Note it's a warning, not an error. Quote
Daklu Posted September 22, 2010 Report Posted September 22, 2010 On 9/21/2010 at 5:27 PM, mje said: I find the warning annoying since I'm trying to clear a re-use library of all warnings, and I need to wade through several of these... Sorry, no helpful advice other than put off that goal for another couple years, or maybe forever if you can. (It is a noble goal--it just doesn't look very achievable right now) Quote
ShaunR Posted September 22, 2010 Report Posted September 22, 2010 On 9/22/2010 at 12:57 AM, Daklu said: Sorry, no helpful advice other than put off that goal for another couple years, or maybe forever if you can. (It is a noble goal--it just doesn't look very achievable right now) Or un-check the "show warnings" when viewing this library Interestingly. If you change something (like mechanical action or the unbundle names). The warnings disappear............until you save it Think you may have found a feature. Quote
TG Posted September 29, 2010 Report Posted September 29, 2010 (edited) On 9/22/2010 at 1:51 AM, ShaunR said: Or un-check the "show warnings" when viewing this library Interestingly. If you change something (like mechanical action or the unbundle names). The warnings disappear............until you save it Think you may have found a feature. I like your attitude ShaunR. Are you sufficiently pissed at the fact that you are stuck using LabVIEW forever? Edited September 29, 2010 by TG Quote
ShaunR Posted September 29, 2010 Report Posted September 29, 2010 On 9/29/2010 at 5:36 PM, TG said: I like your attitude ShaunR. Are you sufficiently pissed at the fact that you are stuck using LabVIEW forever? Stuck? How so? Quote
mje Posted September 29, 2010 Author Report Posted September 29, 2010 On 9/22/2010 at 1:51 AM, ShaunR said: Interestingly. If you change something (like mechanical action or the unbundle names). The warnings disappear............until you save it Think you may have found a feature. I thought that behavior was odd as well. Features are fun! Quote
