jgcode Posted November 6, 2010 Report Posted November 6, 2010 Howdy, a quick question for any math buffs out there, I am sure there is a simple answer! I want to generate the Sine Wave as above using the following function: My question comes from the phase input on the function - what is a formula for converting a starting angle (e.g. 60 deg) into a phase (as it is obviously non-linear)? Also another input is Direction? I want to force which direction the curve will go from the Starting Angle (e.g. Up or Down), this will also change the phase. Obviously I have a workaround here (as per the above graph) which is to use the function with phase set to 0 then iterate through the points and take a subset, but I am certain there is a more elegant solution... but its Saturday Night here and my brain is fried Cheers -JG Quote
Ton Plomp Posted November 6, 2010 Report Posted November 6, 2010 I'm not sure what you mean by phase, but in my book that's exactly the same as the starting angle. If you have for instance a starting angle of 90 degress, you will get a cosine wave instead of a sine. Ton Quote
ShaunR Posted November 6, 2010 Report Posted November 6, 2010 (edited) I'm with Ton on this one Your example screen shot is actually starting at an "amplitude" of 60, not 60°. 90° would start at the peak of the waveform (cosine) so to start at 60° it would be much further up. For the other question. Just use the "change sign" function on the data and start at 180-degrees or -degrees depending on that your trying to achieve.. Edited November 6, 2010 by ShaunR Quote
Francois Normandin Posted November 6, 2010 Report Posted November 6, 2010 Phase of a sine wave wraps every 360 degrees, or 2*PI radian. Some markers: You'll get the initial slope of the sine wave to be negative for any values in the interval ]90, 270[ and positive in the intervals ]0, 90[ & ]270, 360[. 90 and 270 degrees will give an initial slope of zero (cosine and -cosine). 0 and 180 degrees will give an initial slope of 1*amplitude (sine and -sine) Some theory: The sine wave you're generating is of the form: y(t) = A * sin(w*t+ phi) + offset where A is the maximum amplitude w is the angular frequency and is also equal to 2*PI*frequency. Phi is phase in radian. If I understand your question correctly, you'd like to be able to calculate the phase necessary to generate a wave that starts at an amplitude of 60 and specify the initial slope. You want an initial amplitude of 60, so you know that y(t=0) = 60 and your max amplitude is 100. The equation is simple at t=0 => 60 = 100*sin(phi) or Phi = arcsin(60/100) = 0.6435 rad To get it in degrees, divide by PI and multiply by 180. ==> 36.87 deg Your solution will be slightly changed if your offset is not zero... Sine Phase.vi 1 Quote
jgcode Posted November 7, 2010 Author Report Posted November 7, 2010 y(t) = A * sin(w*t+ phi) + offset Sorry if there was confusion in my question, but François nailed what I was after, cheers! Here is the change accounting for an offset (e.g. 90-160 deg waveform) if anyone is interested. This solution is much nicer Quote
