PaulG. Posted December 10, 2010 Report Posted December 10, 2010 My main application controls various tests in 18 different test cells. From my "Main" vi I call up a test cell, test type, parameters, etc. The test grabs a template vi, loads the parameters and this template copy becomes the display and control of that particular test. To reduce screen clutter users can close the running test front panel but can re-open it if they want to check the status of the test later. Problem: a couple of the managers want to monitor these tests from their desks. That does not sound like much of a problem except I want the managers to see the status only and not have any of the functionality of the test interface. What I want: I thought you could call a vi by it's reference and look at it's front panel remotely. No functioning, just display the front panel. But I can't seem to find exactly how to do this without getting into remote front panels which seem like overkill for what I am trying to do. Suggestions? Quote
Francois Normandin Posted December 10, 2010 Report Posted December 10, 2010 Hi Paul, You can set a Web Server: Browser Access to "View Only". Check this link. Quote
asbo Posted December 10, 2010 Report Posted December 10, 2010 Have the VIs write their front panels to disk periodically and point your managers to the samba share. Quote
ShaunR Posted December 10, 2010 Report Posted December 10, 2010 (edited) My main application controls various tests in 18 different test cells. From my "Main" vi I call up a test cell, test type, parameters, etc. The test grabs a template vi, loads the parameters and this template copy becomes the display and control of that particular test. To reduce screen clutter users can close the running test front panel but can re-open it if they want to check the status of the test later. Problem: a couple of the managers want to monitor these tests from their desks. That does not sound like much of a problem except I want the managers to see the status only and not have any of the functionality of the test interface. What I want: I thought you could call a vi by it's reference and look at it's front panel remotely. No functioning, just display the front panel. But I can't seem to find exactly how to do this without getting into remote front panels which seem like overkill for what I am trying to do. Suggestions? This is the sort of thing Dispatcher was designed for. Each cell would have a dispatcher and the manager simply subscribes to the test cell that he wishes to see. You can either just send an image of the FP for a single cell, and/or write a little bit of code to amalgamate the bits they are interested in from multiple cells to make process overviews. Of course it would require the LV run-time on the managers machine. Edited December 10, 2010 by ShaunR Quote
PaulG. Posted December 10, 2010 Author Report Posted December 10, 2010 This is the sort of thing Dispatcher was designed for. Looks exactly like the kind of thing I'm looking for. I'll give it a whirl. Quote
ShaunR Posted December 10, 2010 Report Posted December 10, 2010 Looks exactly like the kind of thing I'm looking for. I'll give it a whirl. Let me know how you get on. I've been meaning to re-visit it, but it dos everything I need it to at the moment so couldn't find an excuse Quote
