MartinMcD Posted January 11, 2011 Report Posted January 11, 2011 Hello again, I have a splash screen which loads at the start up of my vi. I've done it in the usual way - just a vi with the toolbar, titlebar, scrollbars turned off. It works perfectly. However, the vi window has a light grey border which makes it look raised above the desktop. I know it is a very minor thing but I want to get rid of it so I can have a flat splash screen. Has anyone noticed this and figured out a solution? I'll post back if I figure it out myself. Thank you for any help, Martin Quote
mje Posted March 25, 2011 Report Posted March 25, 2011 I ran into this today as well. If I make the window floating, the frame goes away. But if I leave it as a modal window, the border always appears even if it is not re-sizable. I'd like to have a borderless modal window... Quote
Wire Warrior Posted March 25, 2011 Report Posted March 25, 2011 When I want a "borderless" appearance for a VI I use a transparent background. Have you checked out this document http://decibel.ni.com/content/docs/DOC-1086#comment-5644 in the NI Developer community? Jason Quote
Jonathan Borduas Posted April 1, 2011 Report Posted April 1, 2011 Go look at the zip called: Windows API - region functions. at http://lavag.org/topic/13373-front-panel-with-round-corner/ You can change as you want the shape and appearance of your panel and keep the properties of the VI Quote
pawhan11 Posted August 9, 2016 Report Posted August 9, 2016 Has anyone found native solution for borderless transparent modal window? Quote
