brainmort Posted March 1, 2011 Report Posted March 1, 2011 Hi, Right now I am working on a project to create an open Vision-like library for LabVIEW based on Intel OpenCV. At the moment, we don't have enough time and people to wrap all the OpenCV functions, so we could really use some statistics on which functions are essential and which of them could be left for the future. Please, express your opinion here. Thanks in advance 1 Quote
bmoyer Posted March 1, 2011 Report Posted March 1, 2011 Hi, Right now I am working on a project to create an open Vision-like library for LabVIEW based on Intel OpenCV. At the moment, we don't have enough time and people to wrap all the OpenCV functions, so we could really use some statistics on which functions are essential and which of them could be left for the future. Please, express your opinion here. Thanks in advance Wow, that could be quite an undertaking. I wish you luck. Anyway, the NI-VISION functions used depends a lot on the application. Here's a list of the NI-VISION VIs I've used on some recent project. IMAQ Absolute Difference IMAQ AVI Get Filter Names IMAQ Add IMAQ ArrayToImage IMAQ ArrayToColorImage IMAQ CannyEdgeDetection IMAQ Cast Image IMAQ Clear Overlay IMAQ Compare IMAQ Copy IMAQ Divide IMAQ Equalize IMAQ Expand IMAQ Extract IMAQ FillImage IMAQ Find Circular Edge IMAQ Histogram IMAQ Histograph IMAQ ImageToClipboard IMAQ ImageToImage IMAQ ImageToImage 2 IMAQ Mask IMAQ Multiply IMAQ Overlay Bitmap IMAQ Overlay ROI IMAQ Overlay Text IMAQ Quantify IMAQ Resample IMAQ ROIProfile IMAQ Rotate IMAQ Shift IMAQ Subtract IMAQ Symmetry Bruce Quote
mzu Posted March 1, 2011 Report Posted March 1, 2011 So, essentially you are going to repeat this: http://www.hytekautomation.com/Products/IVision.html ? Quote
brainmort Posted March 1, 2011 Author Report Posted March 1, 2011 Well, not really. iVision is a commercial project, what we're making is going to be open source. Besides, strangely enough, they grant much less functionality than IMAQ or OpenCV. 2 Quote
jcarmody Posted March 1, 2011 Report Posted March 1, 2011 [...] what we're making is going to be open source. [...] Don't tease me. I wanna make a dominoes score counter out of a web cam. Quote
Rolf Kalbermatter Posted March 2, 2011 Report Posted March 2, 2011 Besides, strangely enough, they grant much less functionality than IMAQ or OpenCV. Well as you go on with this project you will soon find that it takes A LOT of time and effort to write such a thing, and therefore it is likely that your Open Source library is only ever going to support a fraction of the functionality of IVision and you will understand why they didn't make the entire OpenCV API fully accessible in LabVIEW. IVision as it is, is a really large task in itself to accomplish already and contains quite a bit of work to make the OpenCV API work with good performance from LabVIEW. Sure you could go and simply create LabVIEW wrapper VIs for the OpenCV functions directly without any intermediate DLL but you will soon find out that the VIs created in such a way are kind of hard to develop and maintain and the performance of such a solution is likely going to suffer. The LabVIEW ecoverse is kind of small, and while Open Source can and does work in some areas image acquisition is probably not the most likely one. It requires quite a bit of domain knowledge, a very good programming knowledge and a large amount of time to maintain, and all that for a very small user base. Small because the professionals will use IMAQ Vision anyhow, since it is backed up by NI support, semi professional might go for IVision because of the cost, and the poor students will take whatever is there if they can get it for free, but only really do the minimalistic stuff of accessing a webcam and storing an image to disk, with an occasional simple image analysis function if they even have the time and guts to dive into the theory of how to use that. 1 Quote
vzyubin Posted March 3, 2011 Report Posted March 3, 2011 Well as you go on with this project you will soon find that it takes A LOT of time and effort to write such a thing, and therefore it is likely that your Open Source library is only ever going to support a fraction of the functionality of IVision and you will understand why they didn't make the entire OpenCV API fully accessible in LabVIEW. IVision as it is, is a really large task in itself to accomplish already and contains quite a bit of work to make the OpenCV API work with good performance from LabVIEW. Sure you could go and simply create LabVIEW wrapper VIs for the OpenCV functions directly without any intermediate DLL but you will soon find out that the VIs created in such a way are kind of hard to develop and maintain and the performance of such a solution is likely going to suffer. 1. I have heard, tests show, IMAQ-functions have the perfomance problems comparing to OpenCV (from 1.5 up to 10 times) 2. It seems to me we need: a) a several base functions that solve low level incompatibility problem OpenCV-LabVIEW b) dll-s of OpenCV functions c) a short manual that explanes how to wrap new OpenCV function So, everybody can wrap the functions in need. Obiously, for a lot of simple projects that assume mass yielding it can be the best way to go. Best wishes, Quote
Jon Kokott Posted March 3, 2011 Report Posted March 3, 2011 Convolution was really important last time i did Vision stuff. It is a major processing bottleneck every time. (it would be helpful to have a native function in all datatypes to be sure.) Quote
Luo Feng Posted March 18, 2011 Report Posted March 18, 2011 There is a free toolkit.http://vi-lib.com/index.html Quote
vzyubin Posted September 20, 2011 Report Posted September 20, 2011 (edited) 2 Luo Feng: It seems to me to use the tools you need NI-Vision and then Run-Time-Engine with the IMAQ-abilities (that demands the non-free license). Edited September 20, 2011 by vzyubin Quote
