SuperS_5 Posted April 13, 2011 Report Posted April 13, 2011 Hey guys, The previous post about this was locked, so I couldn't reply there, but I have the same issue. DNS resolution to lavag.org from my laptop fails >80% of the time. I have temporary fixed it by putting lavag in my hosts file. Hopefully you guys won't change your IP too often. The really odd thing is that I can access LAVA from my desktop, and I can access every other website I have tried from my laptop. I have tried flushing my DNS cache, but the problem persists. Quote
Michael Aivaliotis Posted April 13, 2011 Report Posted April 13, 2011 Is your laptop connected to the same internet service provider your desktop is? Quote
SuperS_5 Posted April 13, 2011 Author Report Posted April 13, 2011 This problem occurs on 2 separate networks (Home, and work; both have desktops that can access LAVA) PS: RSS feeds continued to worked sporadically via outlook. Quote
Phillip Brooks Posted April 13, 2011 Report Posted April 13, 2011 Maybe the problem has to do with your service provider's DNS. One way to check it out would be to set your computers or router to use Google Public DNS. Quote
mje Posted April 13, 2011 Report Posted April 13, 2011 The issue has started to creep back up for me as well. On any given day it's a crapshoot whether or not DNS will resolve for lavag. I believe my problem is due to a proxy we have in place at our work, especially since it only applies on hard-wired connections, our wireless works fine. Something about that proxy is seems to pick up bad DNS entries every so often. Given that it involves our corporate network, I anticipate the problem being efficiently resolved some time before our sun burns out. Quote
Mark Smith Posted April 13, 2011 Report Posted April 13, 2011 I see the same thing from work (behind a proxy server) but not from home. DNS fails. Seems to be happening more often now. Then, all of a sudden, it works. Quote
ShaunR Posted April 13, 2011 Report Posted April 13, 2011 Sounds similar to an issue I had once. The provider changed the server I was hosted on and required me to update my NS records to the new server. I added all the new ones but I missed deleting one of the old ones (although I could swear blind I got them all). The result was intermittent DNS lookups because there was a 1 in 3 chance the lookup was done through the old one.. Quote
SuperS_5 Posted April 13, 2011 Author Report Posted April 13, 2011 (edited) Sounds similar to an issue I had once. The provider changed the server I was hosted on and required me to update my NS records to the new server. I added all the new ones but I missed deleting one of the old ones (although I could swear blind I got them all). The result was intermittent DNS lookups because there was a 1 in 3 chance the lookup was done through the old one.. I have Google DNS servers set on my routers. This issue does not discriminate between my wireless or hardwired connections. Accessing LAVA has been flawless since I added the IP to the hosts file. This leads me to suspect there is a bad DNS record for LAVA floating around somewhere out there. Edit: apparently someone switched the DNS server on the router here, so no Google DNS. After switching to Google DNS on this machine, LAVA is good again. Very interesting. Edited April 13, 2011 by SuperS_5 Quote
Michael Aivaliotis Posted April 14, 2011 Report Posted April 14, 2011 Solving this issue is as pleasurable to me as a root canal... Quote
Michael Aivaliotis Posted June 22, 2011 Report Posted June 22, 2011 Hey, what do you know. It seems like I might have finally fixed this DNS resolution issue. Please remove all your hacks and workarounds so that we can truly test to see if this is now resolved. Thank you for your patience. 1 Quote
SuperS_5 Posted July 4, 2011 Author Report Posted July 4, 2011 I removed my "hosts" file work around, and can still get LAVAG. :-) looks good. Quote
Mark Smith Posted July 5, 2011 Report Posted July 5, 2011 I'm good now - I haven't had any problems since you posted the issue was resolved (22 June) Thanks! Mark Quote
