how to get double double click event on empty front panel
pravin
LabVIEW has no notion of a click, let alone a double click. In the past I've handled this with a combination of mouse down/up events. Mouse down records a timestamp and location. Mouse up then checks to see if the location is the same (possibly allowing for some drift) and if it's within a threshold time, registers a click. For a double click, you'd have to add just do this twice.
Yes, I know it's hard to believe that in 2011, LabVIEW still has no idea what a "click" is.
What? Who? But..
Not sure what to say. Part of me is so happy the ability is there. Part of me is annoyed that after over a decade of programming LabVIEW GUIs I never stumbled across that little subtlety. I...just...
Thank you for pointing that out!
  On 9/16/2011 at 1:59 PM, mje said:
What? Who? But..
If I had a quarter for every little subtlety like this that I've missed over the years then I wouldn't have to worry about my retirement anymore. :D
  • 1 year later...
I'm not able to capture this as Double Click. Instead I register a single Left Click, no matter how quickly the double click is done.  Does anyone have a working example of this actually working?
The example code posted by Ton works just fine.  After adding it to a VI you will need to re-link the event to the pane but both the "Mouse Down?" and "Mouse Down" work just fine for stopping the VI only after a double click.
There will always be a single click first. With a double click you will get two events - one for the first click and one for the second. If you want to ignore the first one, use the Double Click terminal to discard the event if it's false.
  • 3 weeks later...
Ah, I thought you'd gone through the trouble of registering for and reporting all the events possible for lots of situations. I've done it a few times before when planning out a UI design for specific cases; I thought I might be able to snag a general-purpose tool. :D
