Hamming Weight and Distance
Wouter
VI Name:
Hamming Weight and Hamming Distance
Total VIs:
2
Description:
One VI calculates the hamming weight, the other the hamming distance,
Note:
Blockdiagram:
Hamming weight (two versions, one with parallel loop, other without, didn't tested which one was faster)
Hamming distance:
What are you thoughts on this VI?
  • Would you like to see such a function in OpenG?
  • Can you optimize the code?
  • In which package should it be included?
  • Should it be rejected?
Given that the OpenG standard is LV9, we should be posting VIs and snippets in that version. It is important to optimize for that version as well.
Yes, please post in LabVIEW 2009 (however, I understand that you may not be able to)
It's just going to make the reviewing process more difficult.
Additionally proposals should be VIs not snippets.
Cheers
-JG
You can if you use the Code Capture Tool. Something could be said about eating dog food...
  • Like 2
As mentioned above - VIs should be posted, as well as (or opposed) to snippets, for reviews.
Save for Previous would be a better workaround to host the VI.
Snippets are good to view the code in the browser (same as posting an image).
Jon isn't one of the CCT developers. That would be Ton (mostly) and me.
I could be wrong but I didn't take that as what jcarmody was saying (as in the context of the conversation I would not be the one using the CCT to post a snippet, Wouter would be) - I took it more as eating the LAVA community's dog food.
And yes, I am not a CCT developer - all props to Ton and Yair :)
