Images in Multicolumn Listbox doesn't work as expected
In the attached example, the symbols are getting displayed in the correct order but missing the symbol for the first row. I can manually select the symbol but by default only the 2nd symbol from the provided array list appear.
Any idea what's the issue?
How to display correct symbol?
Thanks in advance.
Images & Multicolumn ListBox.vi
Nope, Adding an empty image will add one extra element in the multi column list box. This is not what I am looking for.
But 0 is still empty. You'll have to skip zero and start counting at one. (Add an Increment after the iteration terminal in the For Loop).
