Ton Plomp Posted July 11, 2012 Report Posted July 11, 2012 I try to change the version of a library or class with the accompanying VI, and this returns an error 53. Can anyone reproduce this? Ton SetLibVersion.viFetching info... Quote
ShaunR Posted July 11, 2012 Report Posted July 11, 2012 (edited) On 7/11/2012 at 5:04 PM, Ton Plomp said: I try to change the version of a library or class with the accompanying VI, and this returns an error 53. Can anyone reproduce this? Ton I was able to set both class and lvlibs without any problems. How are you calling the VI, i.e. what app refnum are you using? (I ran it standalone) A little later....... I can get error 53 if any of the Major, Minor, Fix numbers are zero. But works perfectly if they are all non-zero Aha! You cannot decrement the version of a user class. So if you are trying to set it to a lesser value, it fails with 53. Edited July 11, 2012 by ShaunR 1 Quote
Ton Plomp Posted July 11, 2012 Author Report Posted July 11, 2012 On 7/11/2012 at 5:41 PM, ShaunR said: A little later....... I can get error 53 if any of the Major, Minor, Fix numbers are zero. But works perfectly if they are all non-zero ... You cannot decrement the version of a user class. So if you are trying to set it to a lesser value, it fails with 53. Hi Shaun, that makes sense, is that also valid for manual changes? I'll have a look at the documentation for that function tomorrow. Ton Quote
Ton Plomp Posted July 13, 2012 Author Report Posted July 13, 2012 Yes, the GUI for a class also limits decrementing the version of a class. Ton Quote
ShaunR Posted July 13, 2012 Report Posted July 13, 2012 (edited) On 7/13/2012 at 9:29 AM, Ton Plomp said: Yes, the GUI for a class also limits decrementing the version of a class. Ton Indeed. In fact it's the same as trying to set the revision number less than the current revision for a VI where it will object with error no. 1077 (which maybe is what it should be for classes rather than 53). My opinion is that version numbers should be able to be set to whatever we want, however. Edited July 13, 2012 by ShaunR 1 Quote
Aristos Queue Posted July 13, 2012 Report Posted July 13, 2012 On 7/13/2012 at 9:48 AM, ShaunR said: My opinion is that version numbers should be able to be set to whatever we want, however. That's nice. Would cause problems for data serialization. Quote
Ton Plomp Posted July 16, 2012 Author Report Posted July 16, 2012 One issue I have with this functionality is that version 1.0 implicitly means 'functional and stable'. How much of you classes are that upon the first save? Ton 1 Quote
