Bobillier Posted September 26, 2012 Report Share Posted September 26, 2012 Hi Perhapse i'm stupid , but i don't find how define default conepane for CTRL-N short cut. Previously i have one "4815" conepane each time, and now it's "4834" . I have try to modify "defaultConPane" parameter in labview.ini but without effect, and when close Labview "defaultConPane" parameter go back to "4834" . Any suggestion? Regards Eric Quote Link to comment
crelf Posted September 26, 2012 Report Share Posted September 26, 2012 The LabVIEWWiki tells us that the defaultConPane key should work for new VIs. Are you saying the LabVIEW.ini file reverts after you make changes and save it? Quote Link to comment
ned Posted September 26, 2012 Report Share Posted September 26, 2012 Just to confirm, you're not trying to edit the LabVIEW.ini file while LabVIEW is running, right? 1 Quote Link to comment
Bobillier Posted September 27, 2012 Author Report Share Posted September 27, 2012 Crelf: Are you saying the LabVIEW.ini file reverts after you make changes and save it? Eric: Yes it's true. Ned: Just to confirm, you're not trying to edit the LabVIEW.ini file while LabVIEW is running, right? Eric: No i stop Labview and modify labview ini and restart Labview.no effect if i creat new vi. Stop labview and look labview ini and then see conepane go back to old value. Just another details: i have samethings on LV2009 SP1 and LV2011 under Windowx XP sp3.. Quote Link to comment
Mellroth Posted September 27, 2012 Report Share Posted September 27, 2012 Crelf: Are you saying the LabVIEW.ini file reverts after you make changes and save it? Eric: Yes it's true. Ned: Just to confirm, you're not trying to edit the LabVIEW.ini file while LabVIEW is running, right? Eric: No i stop Labview and modify labview ini and restart Labview.no effect if i creat new vi. Stop labview and look labview ini and then see conepane go back to old value. Just another details: i have samethings on LV2009 SP1 and LV2011 under Windowx XP sp3.. I believe I had the same issue on LabVIEW 2011. My solution was remove the defaultConPane key from the ini file and start LabVIEW. Stop LabVIEW re-add the ini file token /J Quote Link to comment
Bobillier Posted September 27, 2012 Author Report Share Posted September 27, 2012 (edited) Thanks but for me your trick is not good. If i remove the defaultConPane key and start and stop Labview, the defaultConPane key go back with defaultConPane="4834" in labview.ini file. Edited September 27, 2012 by Bobillier Quote Link to comment
Aristos Queue Posted September 27, 2012 Report Share Posted September 27, 2012 Something must be writing it. Try putting a breakpoint in <LabVIEW>\resource\dialog\lvconfig.llb\LV Config Write Numeric (I32).vi (make a backup copy of this llb first in case you need to restore it) Quote Link to comment
Ton Plomp Posted September 28, 2012 Report Share Posted September 28, 2012 I have the same issue. It's not changed by <LabVIEW>\resource\dialog\lvconfig.llb\LV Config Write Numeric (I32).vi or <LabVIEW>\resource\dialog\lvconfig.llb\LV Config Write String.vi It's changed just before the 'Getting Started Window' is shown It's changed when I open a project from the GSW It started recently. I suspect the f2 patch for 2011 (however my startup window says I only have the f1 patch installed) I have the following providers installed:ADDQ Symbio GOOP [*]It's stored as defaultConPane="4834" [*]I have WinXP with English OS with Dutch localization (a ',' as decimal sign) [*]LabVIEW 11.0.1f1 Ton 1 Quote Link to comment
Bobillier Posted September 28, 2012 Author Report Share Posted September 28, 2012 Ton You are right, it's ADDQ (i don't have GOOP installed) who systematicaly modify the connector pane. To solve this: Go to Tools\G#IDE\Options and Define connector Pane. ADDQ seem have common configuration between all Labview versions installed, because i have made modification on LV2011 and that automaticaly solve this in LV2009 without any action of me. Thanks to all for your help. Regards Eric 1 Quote Link to comment
parthabe Posted July 5, 2017 Report Share Posted July 5, 2017 Eric, Is it because "6x4x4x6" being the first item in the list, and not "4x2x2x4"?! I was facing this issue in LV2016, and it was a nightmare for more than 2 weeks now, until I just stumbled upon this post, esp your reply! Quote Link to comment
