open LV via Application reference
Hi to everybody,
I am about to experiement a little about with application references.
I read that it is possible, to start applications or Frontpanels of VIs.
So I tried to do the same as with the VIPM:
calling the LV-IDE to do a masscompile with some VIs I have.
On my testcomputer I have a few LV-Version installed.
Out of LV11 I wanted to start LV 8.5 to do a masscompile.
But I failed doing so.
Is there a secred on how VIPM do calling the different LV-Versions via a Port-ID
or can somebody explain me how to program such a task?
Greetings
Spirou
Sorry I'm a bit short in time so I'm only going to give you a few links :
- LabVIEW Tray Launcher : is a n app (built in LabVIEW that lets you launch any LabVIEW version that's on you computer
- JKI Fast Mass Compile : a mass compile utility that's faster than NI's
These links should help you with your project, good luck!
I don't know exactly how VIPM deals with this but there are two external interfaces to VI server, either TCP or activeX. My thought is they would have to use activeX to be able to actually launch the application, but this would be Windows only.
Of course there maybe something I'm missing, you could also launch LabVIEW using system exec, but you would not be able to control it through this.
While ActiveX has the feature to also launch the application server there is no reason why you can't use the TCP/IP interface, and I'm pretty sure they do that for multiplatform reasons. You simply have to first launch the executable with System Exec yourself.
The entire VIPM stuff is likely a bit involved and complicated, enumerating the installed LabVIEW versions from the registry, finding their install path, reading (and possibly manipulating) the according LabVIEW.ini file to find out the TCP/IP server properties and then trying to connect to it and in case of failure start it with System Exec and try again to connect.
But it's all doable although the details about timeouts to use when trying to connect can be a lot of trial and error.
