Change the Background (Rotate Func.)
Hi Communtiy,
I have a problem,
I will turn a Picture. The Background is always black. Now, i will change this black to an other color, which i read out from a picture.
The problem is,that the function "getcolorpixel value" don't give me any value on the output "pixel value (U64)"....I get only a value on the output pixel value (U32)........but this output I can't handle with the rotate function
please help me
is there a way to let the background transparent in the rotate function?
Not that I know of - the color doesn't use the alpha bytes, so I think you're out of luck. That said, I can't imagine when I would do that in a machine vision context - what are you trying to do?
Thanks crelf,
I'm not in a machine vision context, I need to realize some custom indicators and I made them superimposing an image to an existent indicator and using the rotate image block.
Just it should be better using a top image with a transparent background...
Max
Hi Guys,
almost 2 years ago I have build a rotate which included the rotation of transparant images.
After reading the 'image data' from a (png-)file you get a 24-bit image together with the mask containing the transparency information :lightbulb:.
See the attached vi (LV 8.5.1)
Rotate Transparent Image (24bit).vi
I think this contains everything you (and hopefully also others) need to do get this done in pure G.
Good luck...
