Save and Write Configuration Settings
Dear Labview Users,
I want to build a VI that can read and write the settings for the controls. The VI should be able to write certain config-settings and be able to read it in the same control.
I found Labview examples (Read Configuration Settings File.vi  and Write Configuration Settings File.vi  both attached below) and the writing of the control-doubles via the Write Key.vi  works just fine.
The problem arises when the config-settings should be read, since a “control” in Labview cannot be used as an “indicator”.
Basically I want to have both VIs (Read Configuration Settings File.vi  and Write Configuration Settings File.vi) in one VI and that the indicator/control on the front panel is the same.
Thanks for your help
Tobi
The main reason I don't use the OpenG panel VIs is that quite often I want only a subset of the controls and it's important not to handle some of the controls I want to avoid. Usually it's either a matter of building the refs array manually or using one or more of the Controls[] properties and then deleting the unwanted refs from that.
Your are right, these VIs should have some filtering functions. E.g. All controls/indicators where the Label Name starts/ends with a certaing character "...$".
Or just have an array of controls refs and only use thoses.
//Mike
