Sharon_ Posted August 25, 2014 Report Posted August 25, 2014 Hi friends, Is there a function available in LabVIEW for opening a folder?. For instance , I save my test results in a folder. I want to have button on my front panel providing option to open and see the contents of the folder. Thanks for your time and support..!!! Sharon. Quote
Sharon_ Posted August 25, 2014 Author Report Posted August 25, 2014 Hi, I think I fount it. http://forums.ni.com/t5/LabVIEW/Use-LabVIEW-to-open-Windows-Explorer-to-a-certain-directory/td-p/898088 Thanks anyway..!!! Sharon Quote
hooovahh Posted August 25, 2014 Report Posted August 25, 2014 Another neat trick is you can open an explorer window, and have a specific file in that folder selected using the /select switch when calling explorer from a command line. I tried this, this morning and it worked but for some reason the new windows were minimized. Probably another switch I'm missing. Quote
Neil Pate Posted August 25, 2014 Report Posted August 25, 2014 Another neat trick is you can open an explorer window, and have a specific file in that folder selected using the /select switch when calling explorer from a command line. I tried this, this morning and it worked but for some reason the new windows were minimized. Probably another switch I'm missing. That should work, it certainly works fine on my PC. It is the technique used by the nifty Show VI In Folder quick-drop plugin http://decibel.ni.com/content/docs/DOC-22461 Quote
hooovahh Posted August 25, 2014 Report Posted August 25, 2014 That should work, it certainly works fine on my PC. It is the technique used by the nifty Show VI In Folder quick-drop plugin http://decibel.ni.com/content/docs/DOC-22461 Yeah I actually took that and modified it to make this QD. https://decibel.ni.com/content/docs/DOC-31302 When using mine, adding the Shift modifier should do just like that function where it shows the file in explorer. Without the shift it does something completely different where it shows the currently opened VIs. I just thought it was a waste to not have some secondary function, especially when QD shortcuts are in high demand. Quote
