Can anyone figure out why this loop isn't stopping?
To clarify, this isn't me asking for help. It's a challenge of sorts, to see if anyone can figure out what I did. :)
EDIT: The trick I used apparently didn't save to the VI snippet. Never mind!
Edited by flarn2006
You must have edited the PNG file directly while leaving all of the header data alone.  When I copied that snippet to a blank VI, that TRUE constant wired to the conditional terminal became a FALSE.
Oops! My mistake. I had hacked the Boolean constants so the true one says F, and the false one says T, but I guess that didn't save in the VI snippet. Never mind! I'll still mark yours as the solution though. :)
EDIT: This works though!
Edited by flarn2006
I still couldn't get that to work, but I understand what you were trying to do.
This ladies and gentlemen is another reason why code review does not replace unit test.
