hms2006 Posted February 2, 2015 Report Posted February 2, 2015 Hi, guys, From the attached image, you can see a stellar form image in black, and some annotation in x, y, d, w , r . x and y are just that we use in cartesian coordinate system; and d is the maximum dimension of the image, which is the span of the particle projected onto a line determined by a least-squares fit of the x and y positions of all occultations; w is the span of the particle projected onto the line perpendicular to that used for d; and r is the correlation coefficient from the least-squares fit. The data of the image is structured in an array with 0 and 1, which is very easy for me to get the dimension in x and y direction. But i really don't know how to get the dimension d, w and r in least-squares fit methods. If i want to realize it in labVIEW G language, can you give me some tips or codes in LabVIEW. Thanks! Quote
infinitenothing Posted February 2, 2015 Report Posted February 2, 2015 You need to convert your array to a list of coordinates and pass it to the linear fit function. Quote
hms2006 Posted February 3, 2015 Author Report Posted February 3, 2015 Get it, thanks for Infitenothing! Quote
