ensegre Posted May 7, 2015 Report Posted May 7, 2015 These days I'm ping-ponging my ongoing project source tree between a development linux system and a test window system, and there is a minor issue which buggers me. The lvproj file is transmutated in a few respects every time it is read by the other platform, and this may generate unnecessary diffs. Usually negligible, as at each commit I typically anyway induce many other changes, though. Looking into, I see: a whole group of items within "Dependencies" is replaced by another one. Where linux has <Item Name="System Exec.vi" Type="VI" URL="/<vilib>/Platform/system.llb/System Exec.vi"/> <Item Name="Get Web Browser Path.vi" Type="VI" URL="/<vilib>/Platform/browser.llb/Get Web Browser Path.vi"/> <Item Name="Get System Web Browser.vi" Type="VI" URL="/<vilib>/Platform/browser.llb/Get System Web Browser.vi"/> <Item Name="Prompt Web Browser Path.vi" Type="VI" URL="/<vilib>/Platform/browser.llb/Prompt Web Browser Path.vi"/> <Item Name="Dflt Data Dir.vi" Type="VI" URL="/<vilib>/Utility/file.llb/Dflt Data Dir.vi"/> <Item Name="Create Directory Recursive.vi" Type="VI" URL="/<vilib>/Utility/libraryn.llb/Create Directory Recursive.vi"/>windows puts a longer block, which includes Registry VIs, ActiveX VIs, BMP VIs and more. I presume that at least some of these deps are due to a little use I make of Report VIs specifically. the entry line for item lvanlys.so is replaced by lines for lvanlys.dll, Advapi32.dll, kernel32.dll the three lines in the Build Specifications block <Property Name="Bld_supportedLanguageCount" Type="Int">1</Property> <Property Name="DestinationCount" Type="Int">2</Property> <Property Name="SourceCount" Type="Int">2</Property>are moved around at different points within the block. Don't know if I'm going to make a big fuss about, just remarking... Quote
ShaunR Posted May 7, 2015 Report Posted May 7, 2015 .lvproj mutates on platform migration Yes it does. Extra info: Real-time targets have no front panels so UI events don't work. Quote
infinitenothing Posted May 7, 2015 Report Posted May 7, 2015 Yeah, I've seen it mutate even without changing platforms. They are delicate. Quote
