ShaunR Posted July 13, 2015 Report Posted July 13, 2015 (edited) On 7/13/2015 at 7:37 AM, peterp said: I also tried to implement a few "NamedPIpe" functions. Nice work. Don't over-reach for a first release. Named pipes for progress bars are a stateful digression from just showing a dialogue. Maybe take stock and put a stake in the ground of where you are - package and clean. Then look at that for version 2. Productionise. Then you can incrementally add features under version control. Just a thought Edited July 13, 2015 by ShaunR 1 Quote
peterp Posted July 13, 2015 Author Report Posted July 13, 2015 You're right, I guess I should "finalize" Version 1.0 of "TaskDialogIndirect". Just for curiosity I had to implement "NamedPipes" function for an LabVIEW application; this is where I got stucked... And, as I mentioned, I do not like a solution depending on another dll, should work "out-of-the-box". Quote
hooovahh Posted July 13, 2015 Report Posted July 13, 2015 On 7/13/2015 at 7:37 AM, peterp said: BTW, I also added a progress bar example of the TaskDialogIndirect. Wow really? I haven't had a chance to try it yet but I sorta agree with Shaun, even though this is a feature I could see myself using. Lots of cool features in this but we need some stability. I mean the structure and file layout alone has changed probably 3 or 4 times since discussions started. And the code could still use some much needed attention in the form of interface, icons, and documentation. Quote
hooovahh Posted July 13, 2015 Report Posted July 13, 2015 I just tested the progress bar and it doesn't work for me. On Windows 7 x64 LabVIEW 2014 SP1 32-bit, the progress window comes up, but the progress bar doesn't move forward. And closing the dialog hangs LabVIEW. I looked into it and for me an error is generated in the Get ProcessIDsOfWindows.vi, and the while loop never stops executing. It should probably stop on error. Quote
peterp Posted July 20, 2015 Author Report Posted July 20, 2015 (edited) I now found the problem with the window handling/handle in LabVIEW 2012, 32bit. Hopefully can solve this soon... BTW: Any idea, why "GetWindow" (of user32.dll) falied with error 1517," LabVIEW: (Hex 0x5ED) An error occurred in the Call Library Node processing." when calling with parameter hWnd, GetNExtHandle (2) ? ... Edited July 20, 2015 by peterp Quote
