rharmon@sandia.gov Posted June 14, 2016 Report Share Posted June 14, 2016 I need to emphasize a portion of a waveform chart. The only thing I can think of is to make two additional plots with only the values I want to emphasize, but that's not working... Anyone pulled this off before??? Thanks in advance.... Link to comment
ensegre Posted June 14, 2016 Report Share Posted June 14, 2016 2 hours ago, rharmon@sandia.gov said: The only thing I can think of is to make two additional plots with only the values I want to emphasize This is what I'd generally do, and end up doinf for things like confidence intervals. What do you mean exactly "that's not working"? Can we see code? You must be familiar btw with ain’t you? Link to comment
Popular Post ensegre Posted June 14, 2016 Popular Post Report Share Posted June 14, 2016 this is a q&d way of doing it (2nd graph with NaNs). Does it qualify? 3 Link to comment
rharmon@sandia.gov Posted June 14, 2016 Author Report Share Posted June 14, 2016 Ensegre, Thank you... Tried everything but NaN.... Works like a charm... Link to comment
ensegre Posted June 15, 2016 Report Share Posted June 15, 2016 The q&d NaN replacement in a duplicate signal is because Waveform Graph was brought into cause in the first place. For large datasets, and multiple graphs, the solution may be less performant; I would then switch to other solutions, like an XY Graph, where each plot can have its own x dataset. Link to comment
ShaunR Posted June 15, 2016 Report Share Posted June 15, 2016 1 hour ago, ensegre said: ; I would then switch to other solutions, like an XY Graph, where each plot can have its own x dataset. I will echo this. 99% of the time you will find that charts are deficient in one way or another. They always start out great as a quick way to visualise data but as soon as the data is not contiguous across multiple plots or you need a data/time axis you always end up switching to the XY graph.I go straight for XY graphs every time. Link to comment
Please sign in to comment
Sign In Now
