Problem for sending 2 CAN frame with different interval
Hello, team:
Recently, I face a problem to send 2 CAN frames with different interval.
i.e.       Frame          Interval
            FrameA         50ms
            FrameB         200ms
The thing is that interval time is the longer one always. I have less knowledge of Labview so far, I don't know which structure could be used in my condition.
Any help would be appreciated. Thanks you.
I don't understand.  Are you writing CAN or reading it?  Are you using NI-CAN or NI-XNET?  What is your hardware, is it NI based even?  Post your code.
That being said I've never had any problem reading or writing CAN frames at different rates in any API.
Oh and if you are new to LabVIEW here is some free training:
NI Learning Center
NI Getting Started
-Hardware Basics
-MyRIO Project Essentials Guide (lots of good simple circuits with links to youtube demonstrations)
-LabVEW Basics
-DAQ Application Tutorials
-cRIO Developer's Guide
Learn NI Training Resource Videos
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
My hardware is NI-USB8473. And what I wanna do is to periodic send CAN frames, but they have difference time interval.
Example, Frame A should be sent by each 50ms and Frame B should be sent by each 200ms.
Thanks very much for your links, do u know how to post a picture, BTW?:)
Here is my current block diagram
CAN tool.7z
 XNET can do periodic frames well; I've done this with the PCI card. The database of frames contains the intervals to send them. As I recall loading the database was all that was needed. Setting the frame values changed what was being periodically sent.
Tks, it seems that couldn't work with the "NI USB-8473"
I have done this in the past with (multiple) NI-USB 8473 and invested hours and hours just to try and keep the frames synced. It's impossible to keep the frames on a certain interval as the OS and the USB will kill your timing. My application experienced delays of more than 400 ms for frames that required intervals of 20 ms! :frusty:
Long story short: Do yourself a favor and use an XNET compatible PCI card, they support periodic CAN frames by design.
You can just drag files in your editor when posting, there is a field just below where you enter your text
Edited by LogMAN
Answering questions :-)
