hexadecimal string in notepad
What do you actually want?  What have you actually tried?  Writing a string to a file shouldn't be difficult, and should be something covered in the first hour of a LabVIEW basics example.
It sounds like you want to store a binary string to a file and then open it and see the hexadecimal values for the bytes.  Notepad only displays file contents as ASCII characters, so you cannot see the actual byte values, only the ASCII characters that correspond to the byte values (the "junk characters" you are seeing).  Can't you just use LabVIEW to view the contents of the binary file?  Read the bytes into a string indicator and set the display mode to "Hex Display".
